Thread started 29 Apr 2011 (Friday) 00:41
Beware of using 580EX II with PocketWizards?
pxchoi
Apr 29, 2011 00:41 |  #1
I'm fairly new to off camera flash but it's something that I'd like to get into. But I read a post on Canon Rumors detailing a report regarding 580 EX II failure when used with Pocketwizards and possible contributing factors.
The report is a little daunting and I simply looked over the conclusions. I remember there being a post about this earlier but I can't remember which section it was posted under so I apologize for a double post.
But I wanted to know if this is something I should be concerned about or should I look at getting a 430EX II to use with a Pocketwizard.
Thanks!
Source (external link)
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
williejr
Apr 29, 2011 01:28 |  #2
Here you go... It's a crap shoot with the 580EXII + tragic wizards :) YMMV as always.
https://photography-on-the.net …088&page=10&hig​hlight=lpa
Body: Canon 5D Mark III, 1D Mark IV,
Lens: 85mmL F1.2, 70-200 L F2.8 II, 24mm 1.4 II L II, 35mm F1.4 L, Flashes: 3x 580EX II,
edge100
Apr 29, 2011 04:21 |  #3
My 580EXII has been flawless with the PW FlexTT5, with the exception of the range issue (which is solved with the AC7).
Others have not been so lucky.
Street and editorial photography in Toronto, Canada (external link)
Mirrorless: Fujifilm X-Pro1
Film: Leica MP | Leica M2 | CV Nokton 35/1.4 | CV Nokton 40 f/1.4 | Leitz Summitar 50 f/2 | Canon 50 f/1.2 LTM | Mamiya 7 | Mamiya 80 f/4.0 | Mamiya 150 f/4.5 | Mamiya 43 f/4.5
How to get good colour from C-41 film scans (external link)
Digitizing film with a digital camera (external link)
CxThree
Apr 29, 2011 07:24 |  #4
No issues here and I use them all the time.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
keyframe14
Apr 29, 2011 07:38 |  #5
I read somewhere that pw was design to work with 430ex and they have problems with 580ex.
www.albert-heisler.com  (external link)
500px (external link)
IG (external link)
edge100
Apr 29, 2011 07:43 |  #6
keyframe14 wrote in post #12315432 (external link)
The issue is that PW didn't test the units with enough of the 580EXII units, and unfortunately they're quite variable in terms of RF noise and overall build quality.
The units work best with the 430EXII, because this flash has the lowest RF noise of any current Canon Speedlite. They also work flawlessly with the old 550EX. The 580EX mkI is also a good choice, in that it won't blow up with the FlexTT5, but it does suffer from the RF noise issue.
ZXDrew
Apr 29, 2011 08:25 |  #7
I blew my 580exii with the TT5. It has been sense brought back to life by CPS.
PhotoWolfe.com (external link)
Facebook.com/PhotoWolfe (external link)
Gear / My flickr (external link)
bobbyz
Apr 29, 2011 08:40 |  #8
No problem here with my 580exII but I prefer to use 550ex over 430exII as 550ex has external power input. I use two 550ex using kacey's dual speedlite bracket.
Fuji XT-1, 18-55mm
AlanU
Gallery: 144 photos
Apr 29, 2011 09:49 |  #9
I think the PW flex pushes the 580exii over the edge if you shoot ETTL in a demanding way. The 580exii is a poorly built flash to begin with interms of electronics and flash bulb setup (lack of venting).
I've killed a couple 580exii's so far with no overheating involved. The flash is labelled as a "flagship" pro flash but its failures are by far much higher than 430exii's. A friend of mine works at a camera shop and sees more 580exii's with issues and 430exii's (pro useage) seem to take far more abuse with more reliability (no external battery pack plugin)
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
CxThree
Apr 29, 2011 09:51 |  #10
Im waiting for the 680 to see what it brings. However, I have not had the issues others have had. Not saying it won't happen, but I have not hit a problem yet.
4x 600EX-RT
dmward
Gallery: 29 photos
Apr 29, 2011 10:00 |  #11
I've had my 580EXIIs fail, one failed again after 6 test flashes on a camera when it came back from CPS.
The AC7 solves the noise problem. I have not had any failures with 580EX, although they are noisy too.
Rob Galbraith tested the Nissin Di688 and found that it does not have noise problem. I have two and find they work well with Flex. LPA has tested them and there is a setting in the misc tab to configure the Flex to recognize them. Essentially the same power, use external battery packs, and are cheaper than 580EXIIs.
AlanU
Gallery: 144 photos
Apr 29, 2011 10:18 |  #12
dmward wrote in post #12316120 (external link)
does the Di688 have a good record of reliability? Just curious because I have interest.
I still prefer speedlite using my flex units with ac3 setup for running/gunning outdoors vs. einstein w/ vml packs.
Fuji - gone
CxThree
Apr 29, 2011 13:06 |  #13
Has the AC7 been updated to not cover the external power port on the 580EXII?
4x 600EX-RT
bobbyz
Apr 29, 2011 13:10 |  #14
AlanU wrote in post #12316219 (external link)
Why not get 550ex? Works like a charm with flexTT5 and AC3.
Fuji XT-1, 18-55mm
klr.b
Apr 29, 2011 14:01 |  #15
CxThree wrote in post #12317102 (external link)
AC57
I think it would cost them too much to retool their molds. Supposedly, they planned the AC7 that way :rolleyes:
gordon
Gear and Feedback
3,099 views & 0 likes for this thread, 13 members have posted to it.
2757 guests, 171 members online
