Could I turn my shutter speed up super high to eliminate all natural light creating only blackness where I don't have light? Can I do this behind a black background? Is this more or less how low-key images are created?
SunnyOctopus Senior Member 455 posts Joined Oct 2010 More info | Apr 29, 2011 11:59 | #1 Could I turn my shutter speed up super high to eliminate all natural light creating only blackness where I don't have light? Can I do this behind a black background? Is this more or less how low-key images are created?
sandpiper Cream of the Crop More info | Apr 29, 2011 12:27 | #2 SunnyOctopus wrote in post #12316810 Could I turn my shutter speed up super high to eliminate all natural light creating only blackness where I don't have light? Can I do this behind a black background? Is this more or less how low-key images are created? The easiest way to remove natural light in a studio, is simply to turn off the room lights and just shoot with the lights you are using for the set, the modelling lights on studio strobes are plenty for seeing what you are doing and focusing..
DaveJr Goldmember 1,873 posts Likes: 1 Joined Oct 2006 Location: MN More info | Apr 29, 2011 12:36 | #3 In my living room studio, with the blinds drawn, I shoot my strobes at 1/160th. Even with daylight streaming into the adjoining room, the ambient light does not register at that shutter speed. As mentioned above, continuous lights would probably be a different story.
BrandonSi Nevermind.. I'm silly. More info | Apr 29, 2011 12:36 | #4 SunnyOctopus wrote in post #12316810 Could I turn my shutter speed up super high to eliminate all natural light creating only blackness where I don't have light? Can I do this behind a black background? Is this more or less how low-key images are created? This will work in any environment.. try shooting most anything at 1/8000 and see what happens.
Apr 29, 2011 12:44 | #5 BrandonSi wrote in post #12316988 This will work in any environment.. try shooting most anything at 1/8000 and see what happens. I know, but I should have been clearer, I meant to ask if the studio lights will show.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 29, 2011 12:50 | #6 SunnyOctopus wrote in post #12316810 Could I turn my shutter speed up super high to eliminate all natural light creating only blackness where I don't have light? Can I do this behind a black background? Is this more or less how low-key images are created? If you are using flash lighting, you cannot use a shutter speed faster than the "maximum sync speed" of your particular camera. If you do try, you will cut off part of the image with the trailing shutter being in the way of the exposure. Skip Douglas
DaveJr Goldmember 1,873 posts Likes: 1 Joined Oct 2006 Location: MN More info | Apr 29, 2011 13:01 | #7 It seems your goal is an unlit black background, is that correct?
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Apr 29, 2011 19:12 | #8 I shoot in the studio at either 1/125 or 1/250 most of the time...and at f8 - f11. No ambient light gets into the photos, and that includes the light from the modeling lamps from up to 5 strobes. You are con tolling all the lighting with your strobes. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
yogestee "my posts can be a little colourful" More info | If you shoot at 125th-250th second and at f11-f16 very little if any available light will be registered. Jurgen
| Latest registered member was a spammer, and banned as such! 2757 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
