My 5 year old has started indoor soccer and basketball classes and I've been practicing my limited sports photography skills at the same time. Unfortunately, I'm not getting the results I want and I believe my problems are mostly due to the poor lighting conditions. I think it's just too dark to get a high enough shutter speed, but I'm wondering if the gear I'm using is also contributing to the problem.
On my most recent attempt at indoor soccer, I used my 5D classic at ISO3200 with my 135L at f/2. I shot in manual, AI servo, center AF point, AF point expansion enabled, without flash, and had trouble getting a proper exposure at 1/640 or faster shutter speed.
Before everyone tells me I'm crazy to use a 5D for sports, let me explain that I started out using my 40D with an 85mm f/1.8 shot at f/2 and ISO 1600 and the results were actually worse. I got lots of noise and was lucky to get a shutter speed of 1/500, so had some noticeable motion blur as well.
I prefer the look of the 5D images at ISO3200 versus the 40D images at ISO1600. However, I am concerned that the 5D AI Servo AF is not up to the task. I have considered replacing the 40D with a 7D which is supposedly much better at higher ISO. Does this make sense?
I have a 580EX flash, but I haven't tried using it since I think I'd end up with dark backgrounds or ghosting if I did. Would using flash help? I will probably give it a try this weekend.
I've also thought about under-exposing a little to get faster shutter speeds and then adjusting the exposure in PP. I'll experiment with this too.
Here are some examples of shots that didn't turn out as well as I hoped:
#1 EOS 5D 135mm f/2 1/640 ISO3200:
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
20110326_2058
#2 EOS 5D 135mm f/2 1/640 ISO3200:
20110326_2057
From the 40D:
#3 EOS 40D 85mm f/1.8 1/500 ISO1600:
20110125IMG_2848
#4 EOS 40D 85mm f/2 1/500 ISO1600:
20110125IMG_2925
These shots are about the best that I've been able to get so far:
#5 EOS 5D 135mm f/2 1/640 ISO3200:
20110326_2059
#6 EOS 5D 135mm f/2 1/800 ISO3200:
20110423_2348
Any help is much appreciated!
