how do you make sure that you shoot w/ the right white balance indoors (so you dont have to fix the white balance in photoshop during processing)? white balance filter?
dingdong Senior Member 250 posts Joined Apr 2011 More info | Apr 29, 2011 17:18 | #1 how do you make sure that you shoot w/ the right white balance indoors (so you dont have to fix the white balance in photoshop during processing)? white balance filter?
lecherro Senior Member 809 posts Likes: 6 Joined Aug 2007 Location: Garland, Texas (Outside Dallas) More info | Apr 29, 2011 17:25 | #2 Should be some kind of setting for indoor outdoor. At the very least there should be a way to shot white and then tell the Camera to use this reference as white. I think thats how most cameras do it. First step........ Take the lens cap off.
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Apr 29, 2011 17:34 | #3 dingdong wrote in post #12318330 how do you make sure that you shoot w/ the right white balance indoors (so you dont have to fix the white balance in photoshop during processing)? white balance filter? The easiest least expensive way is to use a Custom White Balance as per instruction provided with the camera. E.g. take a picture of something that is pure white, focus manually and set the exposure accordingly. Make sure the white object at least covers the center "Spot Metering Circle" area of the focus screen, and then import that image as your white balance data. Tim Kerr
snyderman Cream of the Crop 7,084 posts Likes: 9 Joined Nov 2008 Location: Wadsworth, Ohio More info | Apr 29, 2011 17:53 | #4 when outdoors during daylight hours, choose the 'sun' WB setting. Indoors at night with lights on, use the incandescent setting--looks like a light bulb. Canon 5D2 > 35L-85L-135L
Apr 29, 2011 19:21 | #5 The easiest least expensive way is to use a Custom White Balance as per instruction provided with the camera. E.g. take a picture of something that is pure white, focus manually and set the exposure accordingly I agree with snyderman. This is not the easiest, and it is not not guaranteed to work, because what we perceive as "pure white" can vary quite a bit in color temperature. (I learned this the hard way.) And every time the lighting changes significantly, you have to fuss with setting a new custom white balance. Check out my photos at http://dkoretz.smugmug.com
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 29, 2011 19:36 | #6 Most lighting indoors today is a mixed source...CFL and some incandescent in various fixtures, for example. And such mixed lighting is extremely difficult to balance because the percentage of CFL vs. percentage of incandescent varies entirely upon position in the room! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
NinetyEight "Banned for life" More info | Apr 30, 2011 07:03 | #7 As Wilt says ^^^, shooting indoors these days with artificial lighting can be a right PITA. Kev
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Apr 30, 2011 09:21 | #8 paddler4 wrote in post #12318897 I agree with snyderman. This is not the easiest, and it is not not guaranteed to work, Ok It's the second easiest next to selecting AWB or one of the other presets in camera. Otherwise It Is the easiest and least expensive for anyone who doesn't want to fuss with it in PP. I don't recall saying anywhere that it was guaranteed. You can also do the same using an 18% Graycard to set your custom WB which is more accurate. I believe the owners manual mentions that as well as why. paddler4 wrote in post #12318897 because what we perceive as "pure white" can vary quite a bit in color temperature. White is White, The only thing that would effect the color temperature of something pure white is the lighting, either incident or reflective. Tim Kerr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 30, 2011 09:36 | #9 tkerr wrote in post #12321692 White is White, The only thing that would effect the color temperature of something pure white is the lighting, either incident or reflective. What we perceive as white is most likely what we want our camera to also perceive as white. After all, Isn't that the whole purpose of setting the WB / Color Temperature? I always thought it was so that whites would be white and the colors would be right. . I need to take exception to the above statement. I have done testing with various 'printer paper' selections and found that WB settings from them have been as much as 600K in error, compared to a neutral 18% gray card value (and I have included three different 18% gray targets from different sources in this test with various white papers...WB values are the same with all three gray cards, but changed to other values with some 'white' papers) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Apr 30, 2011 09:42 | #10 or make your own. 1 white, 1 black and 1 18% gray. Kind of risky unless you have absolute faith in your printer profile and are sure your printer is pumping out neutral grey when you tell it to. Elie / אלי
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Apr 30, 2011 09:55 | #11 Wilt wrote in post #12321740 I need to take exception to the above statement. I have done testing with various 'printer paper' selections and found that WB settings from them have been as much as 600K in error, compared to a neutral 18% gray card value (and I have included three different 18% gray targets from different sources in this test with various white papers...WB values are the same with all three gray cards, but changed to other values with some 'white' papers) The problem is that many 'white paper' versions exist, where optical brighteners have been used to improved our perception of 'white' or 'bright' reflectivity. And these brighteners can render a cast which fools WB tools. Then it isn't pure white! Tim Kerr
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Apr 30, 2011 10:00 | #12 tzalman wrote in post #12321764 Kind of risky unless you have absolute faith in your printer profile and are sure your printer is pumping out neutral grey when you tell it to. You're absolutely right. Many newer quality printers are quite accurate. but be careful, some printers might consider neutral gray as 50%. Tim Kerr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 30, 2011 10:15 | #13 tkerr wrote in post #12321819 Then it isn't pure white! ...If you perceive it as white then it is, and that is what you want your camera to perceive as white also. And herein lies the fundamental problem, that what we PERCEIVED as white might NOT in actuality be 'pure white'! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Apr 30, 2011 10:32 | #14 Wilt wrote in post #12321915 And herein lies the fundamental problem, that what we PERCEIVED as white might NOT in actuality be 'pure white'! You don't trust your eyes? Isn't it your eyes you rely on when you look at your picture to ensure they are correctly exposed and the wb is right? Tim Kerr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 30, 2011 11:11 | #15 tkerr wrote in post #12322015 You don't trust your eyes? Isn't it your eyes you rely on when you look at your picture to ensure they are correctly exposed and the wb is right? How would we know if a 18% gray card is actually 18% gray. When using a light meter with an 18% gray card are you going to get it right? Does the camera want to expose at 18% gray? Nope! In an absolute sense I do NOT trust what my eyes perceive as white...simply go to a paint store with all the various shades/hues that we identify as 'white' when we look at one color swatch alone, but then decide it is 'not so white' when we see it side to side with another example of 'white'! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member was a spammer, and banned as such! 2803 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
