huntersdad wrote in post #12329676
Thanks guys. Looks like I have some readin gto do tomorrow as I home with a sick child. I did do a 2nd full recal under the conditions that I would normally edit with the lamp on. As I physically held the calibration monitor to the screen, I am pretty sure very, very little if any light got under it.
Thanks for all the help.
Well, don't take the opposite approach lightly. A lamp that has a color temp especially could mess with things, and consumer lamps will have one -- either tungsten or flourescent.
I keep my editing ambient pretty low, dim daylight or a low, distant lamp. In fact, a lot of professional photography retouchers use a monitor hood, so there is very little ambient light.
Maybe try a few different calibrations, stored with different/descriptive names -- the first two could be in your "normal" editing light with brightness adjusted accordingly and the second two in a dim abient lighting and the brightness adjusted down accordingly. Do the dual approach mentioned above for both -- first, after the monitor has warmed up, and then the second, after the colorometer has warmed up with the first one. That way you will have time to test things out and decide which approach works best. Or maybe you will find use for more than one
