Thread started 01 May 2011 (Sunday) 13:04
Extreme beginner flash meetering question
Norkusa
Joined Jun 2010
May 01, 2011 13:04 |  #1
I've been strictly an ambient-only photographer for years and I'd like to get more serious about wireless/cordless flash photography. Been doing a lot of reading up on the subject and watching tutorial vids on YT. Been messing around with wireless for the past couple weeks now and I think I'm starting to get the hang of it but one thing I'm still totally confused about is how to meeter my flash.
Watched lots of tutorial videos on the subject but I still haven't found one that actually tells you *HOW* to connect your light meeter to your flash/camera. I've go a 7D, 580EX II, and a Sekonic Flashmate L-308B light meeter. I know I need some kind of synch cord but I'm not sure exactly what kind. I've seen 2 different ones - a 3-prong cable and a 2-prong. Which one do I need and why?
5D Mk III • 600EX-RT x 2
Tokina 16-28 • 24-70L II •70-200L IS II •
100L • EF 15mm Fisheye
ScatterCr
May 01, 2011 14:28 |  #2
Most of this information is directly from the Sekonic L-308 manual. I have only included parts relevent to the OP & condensed it. I assume that he doesn't have the manual.
The L-308B has two flash metering modes. One with just a Lightning Bolt & the other with a Lightning Bolt + C. "Lightning Bolt" mode is wireless, "Lightning Bolt + C" mode is wired.
The "Lightning Bolt" mode senses when a flash/strobe fires and gives you an EV (exposure value) or f-stop reading. The "Lightning Bolt + C" mode is used when tethered to the L-308B to tell the meter when the flash/strobe fires.
The L-308B also measures in 1/10th's of a stop. The 1/10th's are not shown in the numerical readout, but rather are shown on a LCD bar dial in the lower center of the screen (same LCD bar dial that indicates battery condition "b.c" when powering up the meter).
Each bar that is illuminated on the dial indicates 1/10th of a stop. The 1/10th bars are added to the numerical reading to give you the total value. For example, a numerical reading of f/2.0 plus five bars equals a total reading of f/2.4 (+5/10th's is halfway between full stops of f/2.0 & f/2.8). 3/10th's is about 1/3rd of a stop, 7/10th's is about 2/3rd's of a stop.
The ISO & Shutter Speed need to be set in the meter before taking a reading. If the measuring range of the meter is exceeded, the digital f-stop number is replaced with "E.u" (underexposed) or "E.o" (overexposed).
To tether to the L-308B, you would use a two prong PC cord of some type. Exactly which cord to use would be determined by what gear you're using & how it's configured. The three prong camera port is for a remote shutter release.
Erik
Gear | flickr (external link)
Norkusa
Joined Jun 2010
May 01, 2011 18:09 |  #3
Thanks Scatter. I didn't have a manual for my light meeter so that helps a lot. Still confused on exactly what kind of synch cord I need to buy but I guess I can just take my meeter down to the local camera shop and they can show me.
Wilt
May 01, 2011 18:24 |  #4
L308 user manual
http://www.sekonic.com​/images/files/L-308.pdf (external link)
577 views & 0 likes for this thread, 3 members have posted to it.
2757 guests, 171 members online
