Thread started 02 May 2011 (Monday) 05:44
POLL: "Ballheads on monopods:with or without plate?"
A ballhead w/fast plate (Arca/Swiss or any other system) for a quick sweep
6
75%
A ballhead WITHOUT fast plate (camera body screwed directly) thus less mobility but safer contact
0
0%
Whatever of the above
0
0%
No ballhead,camera directly on monopod
2
25%
8 voters, 8 votes given (any choice choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
J.Doe
Joined Mar 2011
May 02, 2011 05:44 |  #1
On a given monopod (name your favorite),do you use:
1.A ballhead w/fast plate (Arca/Swiss or any other system) for a quick sweep,or
2.A ballhead WITHOUT fast plate (camera body screwed directly) thus less mobility but safer contact,or
3.Whatever of the above,or
4.No ballhead,camera directly on monopod.
If I'm not asking too much,please justify your option.
...or even post a flaming comment if you think this poll is meaningless!;)
Cheers,
60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
ScatterCr
May 02, 2011 08:00 |  #2
I see no benefit to having a ballhead on a monopod.
Erik
Gear | flickr (external link)
SkipD
Joined Dec 2002
May 02, 2011 08:38 |  #3
ScatterCrSport wrote in post #12331933 (external link)
You must use your monopod only in the classic position.
I use a ball head on my monopod because I use the monopod with the camera at many angles to it other than the 90° that would result by direct attachment.
I don't just stand vertically behind a vertical monopod and aim the camera horizontally. I may be leaning against a tree or a boulder, seated, or in many other positions. My camera may be aimed downward, horizontally, or upward while I am in any of these positions.
Since I use lenses that do not have tripod mounts attached, I need the versatility of a ball head on my monopod as the single-axis monopod heads are not versatile enough.
Skip Douglas
FPP
Gallery: 71 photos
May 02, 2011 09:14 |  #4
Skip is absolutely correct. You cannot always use the monopod in a straight vertical position (and even when you can, this is not the most stable option - see http://www.outdooreyes​.com/photo5.php3 (external link)). I got one of the single-axis monopod heads when I bought it, but traded it in on a ball head the next day. It gives much more flexibility in the use of the monopod.
7D Mark II, 50D, 17-55 2.8 IS, 100-400L IS, 10-22, Sigma 150-600 C, Sigma 150 2.8 Macro, EF-S 60MM f2.8 Macro, EF-S 18-55 IS, 28-135 IS, EF-S 55-250 IS STM, 580 EX II, Yongnuo YN-24EX, JasonC007 Diffuser Kit, Gitzo GT2531EX, ARCA-SWISS Z1, RRS B2 AS II clamp, Kirk L-bracket for 7DII, Kirk L-bracket for 50D
RPCrowe
Joined Nov 2005
May 02, 2011 10:19 as a reply to  @ FPP's post |  #5
I use a single axis head...
I use a KIRK MPA-1 Monopod Swivel which is a Manfrotto Monopod Swivel with a KIRK Arca Compatible quick release.
The problem of shooting with my camera directly mounted to the monopod is shooting up or down. Without a swivel, I would need to tilt the entire pod significantly and therefore reduce the stability.
I don't shoot many images with the horizon significantly tilted, so a left to right tilt adjustment is not necessary for me.
I don't like a ball head because of the extra weight and because when you are using a non-tripod ring equipped camera/lens combination, you must hand the camera cantilevered over to the side.
The MPA-1 allows me to use my RRS L-plates for my camera which maintains the camera directly above the pod for more stability.
1,494 views & 0 likes for this thread, 5 members have posted to it.
975 guests, 123 members online
