Since the example above is a photo taken from the internet (against the rules to post it here, by the way) + a screen capture, the problem is an OS glitch - the Huey not loading its profile - or a corrupt profile. The Huey should do a decent job with the 2209. I have its brother the 2311 and previously when I used the Huey software it was ok (I still use the Huey puck but with different software now). So the first thing I'd say is to recalibrate.
Under Color Management within Windows 7 it's currently set to huey D65 G2.2 A26.54 if that's the correct thing?
Or under Advanced the Windows color system defaults are System Default (sRGB IEC61966-2.1)
If recalbrating doesn't help, I would set the system default to the Huey profile. Click on "Use my settings" and then add the profile into the box if it's not already there and make it the system default.
