Trey T wrote in post #12352136
Somebody should put together a basic guide about video-DSLR and audio requirement for it. It seems there are very repetitive questions going around and round. I can help out by oversight to do the review.
I've been thinking about it, but there is a large variety in technique and budget that it'd be hard to make one standard posting.
Also, as much as possible, try to avoid boosting in post. (It's not always possible, I know, but less boost the better.) The reason is signal-to-noise ratio. Let's just pretend for a moment that your recording system produces a constant hiss at -60dB. If you record hot-ish and your signal is at -6dB, then in post when you boost 6dB your signal is now at 0dB and your noise at -54dB. Excellent! However, let's say you record cold, and your signal comes in at -20dB. Now, you have to boost 20dB, and while your signal is at 0dB suddenly your noise is at -40dB. Eww!
