Thread started 03 May 2011 (Tuesday) 02:00
Energizer Ultimate Lithium in a 580EXII - Batteries hot enough to burn my hand
Bear ­ Dale
"I get 'em pregnant"
May 03, 2011 02:00 |  #1
I used some Energizer Ultimate Lithiums in my 580EXII flash today and probably took around 40-50 flashes. When I took the batteries out they were hot enough to burn my hand, they were almost red hot.
Luckily I didn't keep on taking shots, I'm sure that if I had the 580EXII would have sustained some damage.
Has anyone else ever used Energizer Ultimate Lithiums?
Cheers,
Bear Dale
Some of my photos featured on Flickr Bear Dale (external link)
CxThree
May 03, 2011 06:54 |  #2
I do not suggest using lithium batteries in a flash unit of any brand. Use Eneloops or a similar brand. The lithiums are great pop for the money, but their heat is dangerous in a flash. I've seen the same problems you saw with multiple brands of lithium batteries.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
TMR ­ Design
Joined Feb 2006
May 03, 2011 08:49 as a reply to  @ CxThree's post |  #3
Understanding batteries and battery technology is important, especially with devices like hot shoe flashes.
Lithium batteries are NOT recommended.
Robert
m.comenius
Joined Apr 2011
May 03, 2011 09:07 as a reply to  @ TMR Design's post |  #4
Hmm - I was reading about those lithium batteries and cant understnad why that happens. I never tried, but when i read the technical specifications of the lithium cells I would have done it without any doubt.
Is there someone who knows why its not possible to use it in a flash?:confused:
Greetings from manfred
Please notice, that english is not my nativ language - I will do my best and hope, the best is enough to make me understand
If you like to have a look to my homepage http://www.sehreilig.d​e (external link)
CxThree
May 03, 2011 10:24 |  #5
Heat.
4x 600EX-RT
Blurr ­ Cube
...a lucky id-iot that didn't get electrocuted...
May 03, 2011 10:34 |  #6
fotoworx wrote in post #12337853 (external link)
I started out with alkalines and switched to Eneloops.
If they're too hot to handle then that definitely can't be good. This article states "Avoid HEAT" vmad
http://electronics.how​stuffworks.com/lithium​-ion-battery2.htm (external link)
Remember those battery recalls on laptops?
| Canon EOS Systems |
m.comenius
Joined Apr 2011
May 03, 2011 11:43 |  #7
Blurr Cube wrote in post #12339421 (external link)
I guess its not the same. Those Batteries the TO spoke of are made to be used as AA-size batteries and they are not to be reload.
I dont understand at all that they dont work in a flash.
jmg181
Joined Apr 2011
May 03, 2011 12:29 |  #8
Thats lithium ion, not lithium. Lithium batteries at 1.5V are generally copper or iron sulfide. The issue is not het, so much as heat caused by rapid discharge - like with a flash. They have a very, very high discharge rate, and when you suck it all up at once... bad times.
Most consumer batteries have some sort of discharge protection, but still, lithiums don't fit well for this application.
T3 (1100D) - 18-55mm IS, 50mm 1.8, 55-250 IS
Pics (external link)
Here to learn, feel free to be harsh.
vince_ross
Joined Oct 2004
May 03, 2011 14:58 as a reply to  @ jmg181's post |  #9
Certain batteries just aren't able to keep up with the very fast (and high cap.) discharge of theses flashes. Those just happen to be the ones. They are meant for a longer life at a slower discharge rate. I'd rather have to carry a few sets a $10 AA's with me than risk melting my $500 flash (especially when it's next to my face).
Just another thing to remember, a battery can explode if it gets too hot (even with a discharge protection circuit built-in).
www.ohiovalleyphoto.ne​t (external link)
NG8JGFX
Joined Mar 2011
May 03, 2011 15:02 |  #10
Wow... I neeed to check this out on my 580EXII
MyCanonPhotos (external link) facebook (external link)
Tenba 32L, 5D IV, 5D III, 7D II, 8 Lenses, Three 600 EX-RT's, ST-E3-RT +
m.comenius
Joined Apr 2011
May 03, 2011 15:19 |  #11
NG8JGFX wrote in post #12340892 (external link)
Yes, do, nice. :)
jdmhon
May 03, 2011 15:28 |  #12
I USE APPLE rechargeable batteries!
5D III x2 & FUJI xT-1s: 24L, 35L, 50L 85L II, 100L Macro H-IS, 135L Paul C Buff Lighting
-15" MacBook Pro Retina w/ Capture One & Lightroom 5 -Adobe CS6 Suite -NIK Software Contact: geoffmau@me.com (external link)
www.geoffmau.com (external link)
KurtGoss
May 03, 2011 15:49 as a reply to  @ jdmhon's post |  #13
The Energizer Ultimate Lithium (BLUE PACKAGING) are much stronger batteries, and for that reason they get very hot. You don't want to use those, you want the NiMH one. Less power, but will not melt your gear.
I use regular Energizer NiMH (GREEN PACKAGING) rechargeable batteries, and they work fine.
They are super cheap if you buy them in bulk. I have used them in long shoots, all day long with no issues. If you are using full power, they last about 1.5-2 hours on a 580 EXII -- so I keep a box of about 50 in my camera bag. Yes, they do feel hot after 2 hours, but not anywhere near burning. If you feel more comfortable, change them out every hour.
A dedicated external battery is probably the best way to power flashes, will last longer with less heat. I will probably go that route soon, but in the mean time - cheap AA rechargeable work fine.
I used to use the Eneloops batteries, but they just cost too much. I can get two sets of Energizers for less.
And I use the LaCrosse Charger, allows me to recondition the batteries and know for sure they are all recharging to 100%. The Energizer batteries last about 1 year before they start to not fully charge.
Bear ­ Dale
May 03, 2011 17:48 |  #14
Thanks for all the feedback.
I got a real shock when I took the batteries out. They did actually burn my hand. I can only imagine what would have happened had I kept on using them.
Cheers,
Bear Dale
5,881 views & 0 likes for this thread, 10 members have posted to it.
2741 guests, 171 members online
