I put Phottix ET , but I doesn't make any difference and unable to get focused when I move closer to the subject. Is it because the lens is a Macro (100 mm Macro 2.8L) already or something I did incorrectly? or perhaps it was the ET?
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | May 03, 2011 21:32 | #1 I put Phottix ET , but I doesn't make any difference and unable to get focused when I move closer to the subject. Is it because the lens is a Macro (100 mm Macro 2.8L) already or something I did incorrectly? or perhaps it was the ET? www.eaglesnestphotography.com
ceriltheblade Goldmember 2,484 posts Likes: 4 Joined Mar 2007 Location: middle east More info | May 04, 2011 01:48 | #2 how far away are you from the subject? do the phottix ETs have aperture control? IF not, did you set it up before putting them on? 7D/5dIII
May 04, 2011 07:03 | #3 ceriltheblade wrote in post #12344118 how far away are you from the subject? do the phottix ETs have aperture control? IF not, did you set it up before putting them on? About 3 inches. What does the Aperture has to do with it? www.eaglesnestphotography.com
ceriltheblade Goldmember 2,484 posts Likes: 4 Joined Mar 2007 Location: middle east More info | May 04, 2011 11:24 | #4 connection of aperture COULD be small depth of field. and i would have to get my stuff out but I think 3 inches might be a bit too close ... later I will try to pull it out and measure the distance. how much tube-length are you using? 7D/5dIII
May 04, 2011 15:20 | #5 ceriltheblade wrote in post #12346108 connection of aperture COULD be small depth of field. and i would have to get my stuff out but I think 3 inches might be a bit too close ... later I will try to pull it out and measure the distance. how much tube-length are you using? and just to be sure (not to be insulting) - you are using MF and not AF, right? I tried all combination plus stacked (13,21,31 mm. I also tried both focusing system ( manual and Auto) www.eaglesnestphotography.com
| Latest registered member is ANebinger 1071 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
