Still getting used to my Sekonic L-358 light meter.
I have had very good luck so far with getting good measurments with Ambient light mode in both Shutter Speed priority and Aperture Priority settings. Everything seems to calibrated well.
The problems arise when I am using a flash. This is the most common time I would want to use the meter in the first place.
First, using flash settings mode seems to ONLY allow me to select Shutter Priority mode. This might not be a problem but F stop reading I get are unrealistic and seem totally uncalibrated.
I am using a 28-135mm IS USM with a 580EXII speedlight. I shoot with an ISO between 100 in bright conditions to at the very top range of about 2000 ISO in very poor lighting conditions. I shoot at F3.5 at 28 and F5.6 at 135mm. I will shoot at an F stop of 8 to 10 depending on certain conditions such as if I am needing greatly increase DOF.
Getting back to it.. My L-358 gives wacky values using a flash. First the L-358 starts at F1.0. My starting point is commonly at F5.6 because I am fully zoomed. Because I cannot seem to select Apperture Priority mode to gives me a host of strange values. Lets say I am assusimg SS 1/250 with an ISO of 800 for dark condtiions. The meter might give me an outlandish value of 80 for the F stop. I can of course adjust my ISO and or my Shutter Speed to get me down to realistic F stop values however it leave me something which is horribly overexposed.
I understand there is a calibration mode you cet get into on this meter which might help but I am unsure if this calibration will effect both ambient light and also flash priorty settings. Also I am not sure if I am using the correct dipswitch settings on this meter but under the advice on Youtube I am using 1-2 OFF 3-4 ON.
Have my remote flash trigger on order and should get it next week. I hope this meter wasn't a 350 dollar paperweight. Advice here? Pleaes help!
