Thread started 04 May 2011 (Wednesday) 13:07
Pocketwizard MiniTT1/FlexTT5/AC3 - Quarks with 5D Mark II & 430EXII
m.shalaby
May 04, 2011 13:07 |  #1
So after spending a decent amount of time with this set up, I've found two "bugs" that are consistent.
Bug 1 - FlexTT5 does not fire off 430EXII when camera is in Manual Focus & remote trigger. (As soon as I manually press the shutter button it fires off, and as soon as I put it Auto Focus it fires off). But every time I go backto Manual Focus and remote trigger - flash doesn't fire.
^ I can replicate this over and over. Weird Quark, with No Fix.
Bug 2 - (Camera in Av shooting mode)Shooting at high SS like 1/800 and above with AC3 in "A" mode while works fine. But as soon as I put AC3 in "M" to control output manually, I get rear curtain in image (sync issues).
Fix - Put the Camera in M shooting mode and manually select a high shutter speed like 1/800 or above, fire off flash, no curtain/sync issues appear. Then put it back in Av mode and all is well with the world.
^It seems you have to throw the camera into M mode, fire off a high SS shot, then back to Av mode and the bug goes away. I can replicate this over and over again, usually when I first turn everythying on is when the issue happens. The good part about this is I can fix it by putting the camera in M mode, fire flash, then back into Av mode and its fixed (that is till the next time I turn them off and on again).
Weird quarks... perhaps its just with the 5Dmkii ? Not sure... but this is what I've noticed.
I have 2 430EXII's and 2 FlexTT5's. This happens with both.
CiM_Photography
Joined Sep 2009
May 04, 2011 15:11 |  #2
Which remote trigger are you using? I've got a hunch what might be causing the bug.
Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer (external link) | Gear List>
m.shalaby
May 04, 2011 15:33 as a reply to  @ CiM_Photography's post |  #3
The Canon RC-6
But I don't think its the remote, because as soon as I put the lens in AF and not MF, the flash fires off fine using the RC-6.
Its only in Manual Focus mode that it doesn't fire off... weird.
CiM_Photography
Joined Sep 2009
May 04, 2011 15:48 |  #4
My theory (strictly just that):
My thinking is that there is circuitry/protocol that is being bypassed when using a wireless remote. I'm thinking that by using the wireless remote, instead of going through the full cycle of: shutter-press->are we focusing->what's the metering->fire, it's instead just going straight to fire. At this point, the E-TTL information that it would normally pass over is now empty. Since the FlexTT5 is meant to operate off E-TTL information, it fails to fire.
I strongly suspect that you would find favorable results if you were to use a wired remote.
Again... theory.
1,951 views & 0 likes for this thread, 2 members have posted to it.
2674 guests, 162 members online
