Hello all, hoping maybe someone can help me with this. I purchased this lens on the forum without a hood. I purchased an OEM hood for it and it does not align correctly. When you twist lock it on, it is rotated about 45 degrees beyond proper alignment. This is a petal hood and this cause slight vignetting at the wide angle view.
I purchased a second OEM hood and it has the same problem, so obviously it is the ring on the front of the lens. I don't see any apparant way to twist that ring and correct it.
Any ideas or advice is appreciated.
Scott
