Thread started 04 May 2011 (Wednesday) 18:53
mRAW, purple shadows, why ??
CyberManiaK
May 04, 2011 18:53 |  #1
When bought my 60D I have notice that when I use fill light (under camera raw) was getting a bit of purple on the shadows, then using photomatix with 1 single raw some pics had a lot of purple on the shadows. So i thought it was a defect of the canon raws (I must confess I was thinking on switching to a d7000 )
After a lot of search I found this blog http://dougplummer.blo​gs.com …ller-raw-file-option.html (external link)
So I make a quick test:
Here is the Full Raw (camera raw defaults)
IMAGE: http://farm6.static.flickr.com/5190/5688633444_2765f37bab_o.jpg
mRaw (camera raw defaults)
IMAGE: http://farm6.static.flickr.com/5228/5688633534_abc637d669_o.jpg
Now the Full Raw loaded in photomatix (default parameters)
IMAGE: http://farm6.static.flickr.com/5105/5688633704_f4d57f2ae0_o.jpg
And the mRaw loaded in photomatix (default parameters)
IMAGE: http://farm6.static.flickr.com/5266/5688063697_6141ebbb2f_o.jpg
So... Now I will never shoot in mRaw, was shoting in mRaw because I don't print big and neither crop a lot, so 10mb was fine for me.. But now I will use full raw !!
Now the question is, what's happening with the mRaw to have that purple shadows ??
Cheers.
Carlos
60D / 10-20 + 100L + 40/2.8
MGiddings ­ Photography
May 04, 2011 19:04 |  #2
Not used Photomatix but I suspect it was not designed to process mRAW files. I know DxO can't deal with mRAW.
https://mgiddings.com (external link)
CyberManiaK
May 04, 2011 19:06 |  #3
The problem is also on Camera Raw / Lightroom when used fill light, was getting a bit of purple on the shadows.
I think the problem is because mRaw is not the native resolution of the sensor. But what is doing the camera to make the mRaw ? the million dollar question hahah, some space of the sensor is turned off? the firmware rescale the image? or what lol
Carlos
CyberManiaK
May 05, 2011 00:41 |  #4
Understanding the bayer filter, could this be, because the algorithm used is not taking in account the green channel at 100% to make the mRaw ? Because if we mix the color red-blue we will get purple..
Carlos
picturecrazy
soft-hearted weenie-boy
May 05, 2011 09:07 |  #5
Hmmm.... strange. I don't get any purple shadows using sRAW on my 1Ds3. But then again, I never really looked closely. Now I'm curious.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Keyan
Joined Mar 2011
May 05, 2011 09:10 |  #6
Looks like photomatix isn't designed to handle the mRAW format correctly. There are several programs that won't use it. You could try loading the mRAW into DPP or some other compatible app and then saving it out as a DNG and seeing if photomatix likes that more.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
HughR
May 05, 2011 11:36 |  #7
I use mRAW sometimes with my 60D at high ISOs like 6400. Photoshop CS5 processes them just fine, and there is no problem with purple that I can see. Incidentally, mRAW on the 60D represents a 25% reduction in the number of pixels in each dimension (0.75x0.75x18Mp = 10Mp), so the Canon software is doing a downsizing operation like bicubic interpolation for the downsizing, just as CS5 would. Simply eliminating every fourth pixel in each dimension would produce horrible color artifacts without interpolation.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
CyberManiaK
May 05, 2011 12:28 |  #8
Could be that photomatix is not designed to load the mRaw, but i have seen the problem when Fill light is added, for example like in the blog I mention in my first post. Today I will do some more test but using the fill light, I have found that when the latitude is a bit big (exposing for highlights) and the fill light is needed, then there is the "violeta/magenta/purpl​e" cast.
On this pic is the first I notice when i just bought the 60D, was testing an M42 lens
IMAGE: http://farm6.static.flickr.com/5020/5408361274_f18970445f_b.jpg
The original size is here with exif, http://www.flickr.com …4/sizes/o/in/ph​otostream/ (external link)
And I lifted the shadows. and the background has some purple/violeta cast, I just wipe my HD and i dont have the original file anymore :(
Carlos
tonylong
...winded
Gallery: 60 photos
May 05, 2011 12:37 |  #9
I'd say that you should install the Canon Raw software Digital Photo Professional and use it at least as a reference for these files. The problem my be as simple as the fact that your software does not know how to process the 60D files properly.
Tony
CyberManiaK
May 05, 2011 12:49 |  #10
Tony, I use Photoshop CS5, I see DPP very limited, I give it a try also, but just doesn't WoW me. But what is weird, this only happen with mRaw's and not all of them.
Please don't misunderstand me, i'm not talking bad about Canon, this "problem" lead me to know how the mRaw is created, and that could explain why... could be something technical about the Bayer filter, that is known to have Red/Blue/Green/Green. Because if we mix the color red and blue you will get the color purple.
I'm just curious than something else.
Carlos
tonylong
...winded
Gallery: 60 photos
May 05, 2011 15:28 |  #11
Well, your results from Photoshop Camera Raw are pretty dramatically different from your Photomatix results, so the question is are you seeing something actually in the mRaw or is it just a variation in how software is interpreting the Raw data? I was suggesting DPP because it will give you another "look" in how software is taking different approaches to the data.
Tony
3,232 views & 0 likes for this thread, 6 members have posted to it.
1469 guests, 131 members online
