Thread started 04 May 2011 (Wednesday) 21:08
Help.. problem with aspect ratio of pictures
Big ­ Bad ­ Bill
Joined Mar 2011
May 04, 2011 21:08 |  #1
Hi there sorry for coming in and not introducing myself.. been lurking for quite a while and reading loads.
I've got a problem that has happened quite recently and of my own doing but I can't remember what program i altered to cause this....
HTTP response: 403 | MIME changed to 'text/html' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE
As you can see the two pics are the same just one rotated and the aspect ratio is way off... now here's the embarrassing bit... i remember a popup box appearing asking if i wanted to select Square Pixles and i can't remember if i ticked it or dismissed it or even in what program.:o
since then a lot of my portrait pictures have looked very long looking... any ideas what i could have done cause this?
Even using explorer my thumbnails have the same stretched look, same too in picasa irfanview and photoshop programs.
i have CS5 and Lightroom
I'm not 100% sure but i think the option popped up when i tried using Bridge for the first time.. well that's my best guess anyway... it may have been even in photoshop or lightroom as i had them all open at one time or another around the time when i spotted my problem.
Any ideas or pointers would be gratefully received
Cheers BBB
I should add it's only recent pictures that seem affected
tonylong
...winded
Gallery: 60 photos
May 04, 2011 21:32 |  #2
What OS are you using?
And, do you have/use a video editor? This is a function for video (obviously not for still photography).
I did a Google for "select square pixel and got this page:
http://www.google.com …urceid=ie7&rlz=​1I7ADRA_en (external link)
I may offer you some clues.
Tony
Big ­ Bad ­ Bill
Joined Mar 2011
May 04, 2011 21:41 as a reply to  @ tonylong's post |  #3
thanks for the reply.. I did trawl the net first before posting and came up with similar links mostly referring to video.. but none with my problem or none that i spotted anyway :cry:
Sorry i forgot to say i'm on Windows 7 32 bit.
tonylong
...winded
Gallery: 60 photos
May 04, 2011 23:42 |  #4
Hmm, well I know Photoshop does have some square pixel "stuff", like you said dealing with video, but I know nothing about it.
Tony
René ­ Damkot
May 05, 2011 05:35 |  #5
Big Bad Bill wrote in post #12349423 (external link)
How do you mean? Aspect ratio is 2:3
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
kirkt
May 05, 2011 09:39 |  #6
In PS - look under the "View" menu for the item "Pixel Aspect Ratio" where you can choose the pixel aspect ratio, and "Pixel Aspect Ratio Correction" where you can turn the correction on and off. Did you import a sequence of images into photoshop as an image sequence? This will prompt you in a manner similar to what you are describing. Are you, for example, trying to render a video from a sequence of still images of the helmet to make it look like the helmet is on a turntable and rotating about it center?
Kirk
Kirk
Big ­ Bad ­ Bill
Joined Mar 2011
May 05, 2011 15:44 as a reply to  @ kirkt's post |  #7
I'm a happy boy.... fixed it.... i reset Lightrooms settings to factory and all seems well with the world again :D :D
thanks to everyone for their input...
IMAGE: http://i1101.photobucket.com/albums/g429/baconsbits/MussendenTemple.jpg
kirkt
May 05, 2011 17:26 |  #8
Lightroom?
Kirk
tkerr
May 05, 2011 20:12 |  #9
Not all cameras use square pixels, but I am not aware of anything in LR, Adobe Bridge or ACR that would change the pixel aspect ratio from anything other than the image default, but there is in Photoshop.
Tim Kerr
F1, try it you'll like it.
Big ­ Bad ­ Bill
Joined Mar 2011
May 06, 2011 01:41 as a reply to  @ tkerr's post |  #10
Too good to be true:cry:
i haven't cured it so it's keep trying
Big ­ Bad ­ Bill
Joined Mar 2011
May 06, 2011 04:57 as a reply to  @ Big Bad Bill's post |  #11
I'm using a 400d and i'm afraid i'm a bit ignorant to all this pixel sizes etc.
the screen capture shows what i'm getting below
the image on the left is how my photos appear to me now on my screen.. the one on the right has been scaled to D1/DV PAL (1.09) to make it look right
I'm sure i'm doing something stupid I just need to figure out what that is:)
also on the left image does anyone know what the astrix means after the (RGB/8)*
IMAGE: http://i1101.photobucket.com/albums/g429/baconsbits/Capture2.jpg
Big ­ Bad ­ Bill
Joined Mar 2011
May 06, 2011 05:12 as a reply to  @ Big Bad Bill's post |  #12
right now here's the crazy thing now the screen capture looked fine when i did it on my PC but when i uploaded it to photobucket the left image, the one that appears stretched and the wrong aspect ratio in photoshop is now fine on both photobucket and when posted on this forum... the image on the right... the one i scaled to look right in PS now looks if it's been stretched out width wise in the posted image.
my PC screen resolution is 1360 by 768 if that helps anyway.
I'm really confused now:D
Levina ­ de ­ Ruijter
I'm a bloody goody two-shoes!
Gallery: 457 photos
Best ofs: 12
May 06, 2011 06:17 |  #13
Big Bad Bill wrote in post #12357704 (external link)
It means that the document is in a different RGB colour space than your working space.
Wild Birds of Europe
https://focusonphotogr​aphy.community.forum/t​hreads/wild-birds-of-europe.54/
Focus on Photography (external link)
FlyingPhotog
Cream of the "Prop"
May 06, 2011 06:22 |  #14
Why are you scaling to a European video standard?
Are you producing a video slide show in PAL?
Jay
tzalman
Fatal attraction.
May 06, 2011 07:26 |  #15
I don't understand why you have gotten tangled up in this, but I do know that every camera I've had (five of them) has had non-square pixels and I'd be willing to bet that applies to every Canon EOS. I have never heard of anybody scaling to square pixels in ten years experience with digital photography and I think that it is an absolutely illogical thig to do. It stands to reason that the native capture from the camera is the dimensionally accurate version and any rescaling can only distort it.
Elie / אלי
2,554 views & 0 likes for this thread, 8 members have posted to it.
2882 guests, 177 members online
