Thread started 05 May 2011 (Thursday) 14:45
Contrast confusion
JakAHearts
May 05, 2011 14:45 |  #1
If you have a properly exposed image, does adding contrast cause more lost highlights? So I guess what Im saying is, if I set my black point and exposure so that I have the highlights exactly where I want them, why would I ever want to use the contrast slider? :confused:
Shane
tonylong
...winded
Gallery: 60 photos
May 05, 2011 15:10 |  #2
Well, to me Contrast is a matter of taste that pertains to the individual image. I tweak to get a pleasing look, not just the proper Whites and Blacks.
Tony
JakAHearts
May 05, 2011 15:16 |  #3
Doesnt that give you lots of blown out areas? It seems that even a slight contrast boost of 2 or 4 triples the amount of red highlight warnings.
Shane
ChasP505
"brain damaged old guy"
May 05, 2011 15:20 |  #4
JakAHearts wrote in post #12353665 (external link)
There's a technique where in LR or ACR, instead of adjusting the Blacks slider, briefly go into the Tone curve tab and adjust the Shadow and Dark sliders. This will preserve your highlights.
http://www.retouchpro.​com …etouchPro_Maxim​um_raw.pdf (external link)
Chas P
JakAHearts
May 05, 2011 15:24 |  #5
Thanks Chas. Ill check it out.
Shane
tzalman
Fatal attraction.
May 05, 2011 16:53 |  #6
An S-shaped curve increases contrast without affecting the white and black points so long as the ends of the curve are not moved.
Elie / אלי
agedbriar
May 05, 2011 18:02 |  #7
1. Why?
Because setting the black and white points right doesn't guarantee the necessary overall crispness, especially when dealing with lots of midtones.
2. How?
Not by the use of the Contrast slider, as that may indeed produce blocked shadows and/or clipped highlights. The easyest (and tone-wise locally adaptive) is the use of the S-curve, as Elie showed above. Another solution is Local Contrast Enhancement that some programs offer with the Clarity slider. If you don't have the latter, you can do it with Unsharp Mask, by setting the parameters to about:
Amount 15-20
Radius 50
Threshold 0.
frenchconnector
May 05, 2011 18:16 |  #8
tzalman wrote in post #12354310 (external link)
+1
Use curves for contrast adjustment and nothing will get blown. Learn how to use em and forget about contrast slider forever.
igorpilot.com (external link)flickr (external link)tweet tweet (external link)
agedbriar
May 05, 2011 19:10 |  #9
Overall contrast reduced and replaced with local contrast:
JakAHearts
May 06, 2011 06:37 |  #10
frenchconnector wrote in post #12354745 (external link)
+1
Thanks! This seems like what Ive been doing. I still get good contrast in my edits. I just didnt understand why the contrast slider was even there.
Shane
René ­ Damkot
May 06, 2011 08:33 |  #11
Contrast slider in LR3 changes midtone contrast. Same for the contrast slider in ACR and Photoshop CS4 and later. These will not (hardly) affect clipping.
It's the "Legacy" contrast slider in Photoshop that sucks.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
939 views & 0 likes for this thread, 7 members have posted to it.
Contrast confusion
2883 guests, 177 members online
