Thread started 05 May 2011 (Thursday) 16:58
ef 70-300mm f4-5.6 L IS USM, pros & cons
okiebirdnerd
May 05, 2011 16:58 |  #1
Okay, I’m buying a T3I body and want to buy one lens. I mainly shoot birds. I’m thinking about the ef 70-300mm f4-5.6 L IS USM. I want to hand hold and keep the weight down. I only want to do this once and don’t want to regret not getting the right lens. The camera and lens together weigh 3.5 pounds. I also looked at the 70-300 non L and it seems to be a bit soft at full zoom and I’m sure I’ll max out the zoom. I hate spending 1500.00 on the L but what I’ve read is it’s a great lens. I’d appreciate any suggestions. Thanks in advance!
Wile_E
May 05, 2011 17:05 |  #2
for what you want to do and spend, it sounds like the 70-300is is the right lens for you.
SamuelYCWang
May 05, 2011 17:25 |  #3
A Rebel body and a lens such as the 70-300 is still going to be uncomfortable in your hand after awhile. Also, I'm not a variable aperture type of guy, but this lens seems to perform pretty well. Have you looked into the 55-250?
Canon 5D MK III
EF 17-40 f/4L USM
ER 50 f/1.2L USM
EF 24-70 7/2.8L II USM
EF 70-200 f/2.8L IS II USM
crn3371
May 05, 2011 17:53 |  #4
Is this your first dslr? Will the 70-300 be your only lens. If yes to both I'd suggest you start of slowly and get something like the 2 lens kit with he 18-55 and 55-250. Nothing wrong with the 70-300L but I wouldn't want it as my only lens. The 2 lens kit will give you a stabilized range of 18mm to 250mm without costing you an arm and a leg. For birds, the longer the better. 300 mm would be at the short end for birding. It'll work, but usually 400mm and up is preferred.
okiebirdnerd
May 05, 2011 17:55 |  #5
No, I didn’t even consider the 250. I’ve been using a 28-400 mm super zoom and it weighs 2.5 pounds. So I’m adding a pound. The 70-300 non L only weighs ½ pound less than the L so my thinking is I can tough out holding an extra ½ pound for a faster better lens.
crn3371
May 05, 2011 17:58 |  #6
Don't worry about the weight. Any comments you get regarding a heavy lens on a Rebel body are referring to the ergonomics, not whether the camera can handle it. This is why many users stick a grip on their body.
okiebirdnerd
May 05, 2011 18:00 |  #7
I told my husband this is my last camera:oops:….if I tell him this is for “starters” it won’t go over too well.:cry:
District_History_Fan
May 05, 2011 18:02 as a reply to  @ okiebirdnerd's post |  #8
I'm thinking you may need more than 300mm. :)
www.ericmcferrin.smugm​ug.com (external link)
okiebirdnerd
May 05, 2011 18:11 |  #9
Well if I read correctly, with the lens I want, I can add the Kenko GDX 1.4x and retain the AF. You are stuck without options if you get a non L lens.
If I can just get the camera and lens in my hand it won’t matter that I told him this would be my last camera.:oops: It should keep me happy for at least six months.;)
bob_r
Gallery: 24 photos
May 05, 2011 18:13 |  #10
District_History_Fan wrote in post #12354667 (external link)
+1^^
I have very few bird shots taken at less than 300mm and most of those were because I wasn't planning on shooting birds at the time. Most of my bird shots are at 400mm or over (using teleconverters).
Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Sigma 150 macro, 1.4X, 2X, Quantaray 2X, Kenko closeup tubes, Yongnuo YN685(3), Yongnuo YN-622C-TX. Lots of studio stuff.
** Image Editing OK **
May 05, 2011 18:15 |  #11
okiebirdnerd wrote in post #12354716 (external link)
Sigma 120-400 OS and 150-500 OS. Not sure the 70-300L is compatible with extenders...
okiebirdnerd
May 05, 2011 18:18 |  #12
So you don't think the Kenko would help? The main reason I'm going with the T3I is because it is light. The 100-400L is over 3 pounds. I have read in three different places that it will work.. I guess they can be wrong.
bob_r
Gallery: 24 photos
May 05, 2011 18:21 |  #13
okiebirdnerd wrote in post #12354762 (external link)
If this lens is just for birds, get the 400 f/5.6. It's lighter than a 100-400 and it's longer and cheaper than the 70-300L (it's probably lighter too after you add a teleconverter to the 70-300). It doesn't have IS which is helpful if you plan on handholding which is why I went with the 100-400. The 100-400 is probably about the same weight as a 70-300L with a TC.
Just checked Amazon and a Kenko 1.4X PRO 300 Teleconverter DGX weighs over 7 ounces. I don't know if this is the one you're considering, but the weight should be similar.
liupublic
May 05, 2011 18:22 |  #14
For birding, 300mm on a crop is probably a bare minimal. 100-400L would likely be better but will be heavier. Other possible options. All of them are quite heavy and large.
Sigma 120-400 OS HSM
Sigma 150-500 OS HSM
Sigma 50-500 OS HSM
Another alternative:
7d + Tamron 70-300 VC. 7d will provide quicker and better AF system. Much higher frame rate as well. Both are critical for birding. Tamron 70-300VC will provide somewhat reduced IQ compares to 70-300L, but it's only $450.
Still learning
Nikon D750, Sigma 24-105OS, 105mm 2.8g micro VR, Tamron 70-300VC
crn3371
May 05, 2011 18:35 |  #15
Very seldom will you see the words long lens and lightweight used in the same sentence. The 70-300 won't AF with a tcon. Maybe if you tape the pins, but slow and iffy at best.
5,543 views & 0 likes for this thread, 14 members have posted to it.
1503 guests, 131 members online
