I got a Sigma 30mm 1.4 today. I put it on my camera using my flash bracket, but the metal of the flash bracket scratches the lens. Is this normal? Any ideas? I'm a little upset that my new $500 lens already looks old. :c
SunnyOctopus Senior Member 455 posts Joined Oct 2010 More info | May 05, 2011 22:08 | #1 I got a Sigma 30mm 1.4 today. I put it on my camera using my flash bracket, but the metal of the flash bracket scratches the lens. Is this normal? Any ideas? I'm a little upset that my new $500 lens already looks old. :c
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 05, 2011 22:13 | #2 Which flash bracket? I wouldn't think it's normal. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
May 05, 2011 22:17 | #3 http://www.amazon.com …TF8&qid=1304651799&sr=1-3
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | May 05, 2011 23:43 | #4 That's not even a big lens! That's just a poor design. I'd be pretty pissed off about that, too. gordon
May 05, 2011 23:55 | #5 Is there any better alternative? Maybe I can glue a soft covering over the edge of the metal thingie? :c
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | May 06, 2011 00:42 | #6 It's hard to say without seeing a pic of it mounted. If it's scratching the lens now, adding material won't really help since it'll still rub. Is there any room for adjustment? Maybe you can move the camera to the right or back towards you. gordon
Sirrith Cream of the Crop More info | May 06, 2011 00:45 | #7 If a flash bracket scratched my little 30, I think it would become 2 or 3 flash bracket pieces. -Tom
May 06, 2011 01:04 | #8 klr.b wrote in post #12356958 It's hard to say without seeing a pic of it mounted. If it's scratching the lens now, adding material won't really help since it'll still rub. Is there any room for adjustment? Maybe you can move the camera to the right or back towards you. Are you sure? If I add material, won't it rub up against something soft and harmless?
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | May 06, 2011 03:04 | #9 Like I said, i can't say for sure without seeing it. If it's scratching now, that means there's no room between the lens and part of the bracket. Even if whatever you add is soft, it's still going to rub. Most likely that material will inhibit the camera from rotating. Generally, when something like this happens, you remove material, not add it. If you're handy with a Dremel and don't mind modifying your bracket, you can grind the bracket a little as a last resort. Just make sure that you're mounting the camera correctly and that it's not your fault the bracket is scratching your lens. gordon
| Latest registered member was a spammer, and banned as such! 2662 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
