Thread started 06 May 2011 (Friday) 09:42
Which ISO ranges do you use indoors w/o a flash
BaghdadFred
Joined Nov 2010
May 06, 2011 09:42 |  #1
Now that I am using a light meter to shoot with, it is giving me reading that I may not have considered before using ambient light only.
I would rarely shoot at ISO ranges above 2000 ISO due to noise. Although I can control noise very well using lightroom.
Is it possible to shoot in the 2500+ ISO range and still get sharp photos?
Fred - Photographing everyday Military life in Iraq (external link) | SmugMug (external link)
7D | C 100-400L | Σ 70-200 2.8 OS | Σ 30 1.4 | C 10-22 | Σ 8-16 | C 17-55 2.8 IS | C 28-135 IS | 580EX II | Σ 1.4x
Red ­ Tie ­ Photography
May 06, 2011 09:45 |  #2
I shoot 3200 often during receptions.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
May 06, 2011 09:48 |  #3
It really depends on your camera. While all of them have higher ISO settings, they are certainly not equal in terms of performance. I can use my 5D at 3200, but have to be very careful as there is little exposure latitude at that ISO for missed exposure. My 40D struggles to please me at 1600.
smorter
May 06, 2011 09:48 |  #4
Yes often ISO 1600-3200 is the go for me during receptions and parties and indoor events
As I use all prime lenses typically wide open, sometimes I can creep down to ISO 800 or even lower if I'm lucky or the venue is brightly lit. Extremely rare though.
Regarding ambient light only, these are crapshoots, I've had to do shoots at like ISO 12,800 equivalents (3200 pushed 2 stops in DPP) with f/1.4 and f/1.2 lenses! Very noisy, very soft and only good for small output (i.e. websize)
Wedding Photography Melbourneexternal link
Reviews: 85LII
talbot_sunbeam
May 06, 2011 09:51 |  #5
I'm ok at 800, but am very nervous at 1600, on my XSi.
7D, 450D | 17-55, 10-22, 55-250, 50 1.8, 580EXII | YN568II | YN622 x3 | Magic Lantern | (Still) Jonesing for a 70-200 2.8...
Turns out a gripped 7D + 622 + 580exII + 70-200 2.8 IS MK2 is BLOODY HEAVY! Who knew?!!
smorter
May 06, 2011 09:55 |  #6
I upgraded to a 5D2 from a 40D and 400D (XTi).
At ISO 1600 the 40D is a smidge better than the 400D. But the 40D is pretty much the same as the 5D2 at ISO 1600.
The advantage of high ISO capable cameras like the 5D2 is that if you underexpose at ISO 1600, you can easily recover the shot by pushing 2 stops in post. If you try that for the 40D the file turns mushy, soft, magenta and crazy noise filled
But at a baseline ISO 1600 amount without any pushes, there is little, if any difference between most cameras newer than the 400D (Xti).
Reviews: 85LII
Kechar
Joined Mar 2011
May 06, 2011 10:04 |  #7
I won't shoot above 800 with my 40D...don't like the results :(
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
Echo63
May 06, 2011 10:17 as a reply to  @ Kechar's post |  #8
I use 6400 on my mk3 fairly regularly, and have used 12800 on the mk4 quite a few times
I would not hesitate to push the iso to H3 on the mk4 if I really needed the shot, although printing on newspaper hides a bit of noise
I generally use flash to fix poor light quality, rather than light quantity now I have the mk4
Back when I was shooting with a mk2n I tried to not go past iso1000 if I could help it
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
Bobster
May 06, 2011 11:19 |  #9
12,800 on my 50D if required
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
Kechar
Joined Mar 2011
May 06, 2011 11:26 |  #10
I turn off ISO a lot of the times. It can help in some situations! :D
849 views & 0 likes for this thread, 8 members have posted to it.
2662 guests, 162 members online
