Thread started 06 May 2011 (Friday) 13:53
Gimmie the real skinny on guide numbers
dan.k78
May 06, 2011 13:53 |  #1
I'm looking to upgrade flashes in the near future and have started to "do my homework". Ideally, I'd love to just whip out the credit card toss a 580EXii into the cart and call it a day. Unfortunately, I can't justify it quite yet. So, I've been looking into the 430EXii and it's counterparts from Nissin and Metz. One of the specs that is always at the forefront is the guide number. Now, I have a basic understanding of what the number means, but I'm curious as to how it can/would impact me in the real world. In other words, have any of you felt that flashes along the lines of the 430EXii are noticeably lacking in power compared to a 580? How important is flash "power" in terms of shooting events (most specifically weddings)? I understand that every situation is different, so I'm more or less interested in answers that focus on "most of the time" or "usually". Thanks in advance.
Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
airshaq20
May 06, 2011 16:45 |  #2
In my real world experience, between the 580ex2's and my former 430ex's - when I shoot indoors, I never used full power. Outdoors is a different story because you need all the power you can get.
As for the master/slave feature, I only used it a couple of times years ago, and quickly discovered that they are pretty much useless when there is a sun.
If you are doing primarily weddings, then get a flash with TTL as it will be almost impossible to use manual flash the whole time.
If you are going to shoot in a controlled environment (i.e. studio, home-studio, etc), then here's what I would suggest. I would get a cheap TTL flash (popular off-brand) to use during the days that I am lazy and buy cheap manual Nikon/Canon flashes and cheap triggers when I want to be creative.
The only thing that I will be missing from the above setup is high speed sync - which I never use because I'm too chicken to kill my $450 flash!
But if you will just use flashes for weddings, instead of buying a 580ex-2, get two Sigma equivalent for about the same money.
Wilt
May 06, 2011 18:11 |  #3
On-camera flashes really make life difficult by the fact that every different FL coverage angle creates a diferrent guide number. If all flashes have 105mm coverage angle, you can do direct comparison. But if some flashes are fixed angle (e.g. 35mm FL coverage) you first have to find out the zoom head GN for the same coverage FL or else your comparisons are apples-vs-oranges.
As for what different GNs represent in the 'real world', simply divide each GN by 4, and that would tell you what the maximum distance that the flash would reach if the lens were set to f/4...the farther, the better.
Then you further complicate comparisons with 'feature list' comparisons...ETTL or not, wireless flash or not, master/slave capable or not, HSS or not, stroboscopic mode or not, number of manual flash power levels available, etc.
williejr
May 06, 2011 22:46 |  #4
Someone asked Joe McNally during one of his tours about guide numbers when working with speedlights and he didnt even know...lol
I've shot weddings with both the 580EX II and 430EX II... I couldn't really tell you the difference. I can tell you, the fact that I can not attach my battery pack to my 430EX II makes it a backup flash and sits in my bag.
Body: Canon 5D Mark III, 1D Mark IV,
Lens: 85mmL F1.2, 70-200 L F2.8 II, 24mm 1.4 II L II, 35mm F1.4 L, Flashes: 3x 580EX II,
yogestee
May 07, 2011 01:28 as a reply to  @ williejr's post |  #5
A GN of 60 meters on one flash often doesn't equate to a GN of 60 metres on another.
A little like motorcyle manufacturers. Some makers rate their power output at the crank, some at the rear wheel.
Jurgen
fransener
May 07, 2011 02:47 as a reply to  @ yogestee's post |  #6
GN need 3 additional qualifiers to be meaningful:
- reflector position
- ISO
- unit meters / feet
If all 3 are known then it's easy to compare different flashes! Many flashes have a guide number table in the instruction manual with GN for different zoom reflector positions, and ISO is mostly set to 100 - although there are some "smart" marketing people who use GN for the ISO-200 setting which lets their flash appear 40% more powerful.
http://speedlights.net (external link)
edge100
May 07, 2011 07:57 |  #7
The 430EXII is only slightly less powerful than the 580EXII, especially when used with a modifier. The Nissin Di866 is slightly more powerful than the 580EXII:
http://www.robgalbrait​h.com …p?cid=7-10050-10598-10599 (external link)
Street and editorial photography in Toronto, Canada (external link)
Mirrorless: Fujifilm X-Pro1
Film: Leica MP | Leica M2 | CV Nokton 35/1.4 | CV Nokton 40 f/1.4 | Leitz Summitar 50 f/2 | Canon 50 f/1.2 LTM | Mamiya 7 | Mamiya 80 f/4.0 | Mamiya 150 f/4.5 | Mamiya 43 f/4.5
How to get good colour from C-41 film scans (external link)
Digitizing film with a digital camera (external link)
msowsun
"approx 8mm"
Gallery: 18 photos
May 10, 2011 07:53 |  #8
airshaq20 wrote in post #12361106 (external link)
I don't understand your statement. Why do you think HSS is hard on your flash?
rhys216
May 10, 2011 09:49 |  #9
It is if your using a 580exii with a TT5.
Also HSS has longer flash durations which sucks battery power, and in turn probably generates more heat.
Aside from using it with a TT5, I wouldn't be scared of HSS though...
1,540 views & 0 likes for this thread, 9 members have posted to it.
1062 guests, 104 members online
