Thread started 06 May 2011 (Friday) 19:34
ST-E2 problem
Michelle ­ Brooks ­ Photography
Joined Sep 2009
May 06, 2011 19:34 |  #1
Tonight I put my new (used) ST-E2 on my 5dMKII, put my two 580EXII flashes on stands and proceeded to get totally frustrated because I couldn't get the ST-E2 to fire my flashes. I know (from experience) that it's something simple I am not doing but here are the steps I followed:
  • I set my flashes to slave setting and Channel 1 in Manual mode
  • I turned the ST-E2 on, made sure the Ratio lamp was not on per instructions
  • I made sure the Assist beam flash was emitting at 1 sec intervals on my flashes
  • I made sure the flash sensors were facing the St-E2 and not obstructed
  • I was only about 5 ft away
But the Pilot lamp on the ST-E2 would not light (I had checked it when I first got it & it did light and the assist beam did fire when the pilot button was pressed). Is there something I am supposed to set in camera? Any toher suggestions?
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
TopHatMoments
May 06, 2011 20:21 |  #2
Is the battery in the ST-E2 dead?
Canon to PhotoShop, “Beam me up”! LR3 set course for CS5, Warp speed 64!___ ((dpp___/==***^***
Joined Sep 2009
May 06, 2011 20:26 |  #3
TopHatMoments wrote in post #12362052 (external link)
Doesn't seem to be; the Channel lamp & Ettl lamp is on...that is one thing I wondered about, if because I have the flashes in Manual mode the ST-E2 is somehow in Ettl (tho I saw nothing in the instruction manual about changing that)?
TopHatMoments
May 06, 2011 20:34 |  #4
I'd have to break mine out an look and it's miles from where Im at.
As long as there is something to reflect or direct the beam into the sensor, they should fire,
Your camera is set to fire the flash, the 5's are set to slave and your group #er matches, ratio would affect a 2 group setting.
I us mine but, have for so long it's automatic and one of them things that slips all thought till there in hand.
Savas ­ K
May 06, 2011 20:57 |  #5
Read this:
http://www.learn.usa.c​anon.com …ite_tip_pt3_art​icle.shtml (external link)
Joined Sep 2009
May 06, 2011 21:17 |  #6
That was a really in-depth article but I didn't really see anything that pertained to my problem; did I miss something?
windpig
Chopped liver
May 06, 2011 21:45 |  #7
I just set my 430EX II to:
M
Channel 1
Slave
1/2 power
ST-E2
Ratio on or off
Channel 1
Pilot light turns on when on or hold
flash fires
you may have a tired battery.
Go ahead, spin the wheel.
Frogday
May 06, 2011 22:37 as a reply to  @ windpig's post |  #8
The lights on the back of the ST-E2 take less power than it does to signal the flashes - they will still light when the unit doesn't have enough power in the battery to operate. If you press the test button you can see it make the signal flash in the top section on front. Try that and if you see nothing, try it with a new battery.
5D MIV | 5D MII | 7D | 30D | D30 | A2E | Elan 2e | AE1p | FTb | SD1100IS | G7x
EF 85 F1.8 | EF 100 F2.8 macro | EF-S 15-85 IS
EF 24 F1.4L II | EF 35 F1.4L | EF 85 F1.2L II | EF 135 F2.0L | EF 8-15 F4L | EF 11-24 F4L | EF16-35 F2.8L II | EF 24-70 F2.8L | EF 24-70 F2.8L II | EF 70-200 F2.8L IS II
Savas ­ K
May 07, 2011 05:29 |  #9
Half of all computing problems go away by checking the power cable.
Joined Sep 2009
May 07, 2011 12:21 |  #10
Well guess what? It was the battery! Put a new one in and shazaam! Everything working! Thanks guys!
NavyShrink
Joined May 2011
May 10, 2011 00:26 as a reply to  @ Michelle Brooks Photography's post |  #11
Same problem as above, not resolved by new battery (just made trek to Radio Shack and back). Pilot light on ST-E2 simply won't come on. Channel light and "ETTL" both light up, but pilot light stays unlit. It doesn't respond to pressing it either. This worked last time I used it. Nothing has changed. It sat in its case since I last used it. I'm truly perplexed. Any help would be appreciated. Thanks.
5DII x2 | 7D | 17-40L | 35L | Σ 50 | 85L | 135L | 70-200L IS II | Fuji X100
Joined Sep 2009
May 10, 2011 13:26 |  #12
NavyShrink wrote in post #12380544 (external link)
That bites! I'm so glad a new battery solved my issue. Any chance you got a bum new battery?
1,365 views & 0 likes for this thread, 6 members have posted to it.
ST-E2 problem
2539 guests, 156 members online
