Thread started 08 May 2011 (Sunday) 14:08
How to stack dual images in one ?
m.shalaby
May 08, 2011 14:08 |  #1
Simple enough it seems, but I can't figure it out... how do you stack two images in one like this example ?:
http://www.flickr.com …8/sizes/l/in/ph​otostream/ (external link)
René ­ Damkot
May 08, 2011 14:15 |  #2
What software?
Photoshop:
Open two the images.
In one image go Image > Canvas Size.
Double the canvas size, tick the top box, so the canvas expands down only:
IMAGE: https://img.skitch.com/20110508-e2c59dhpck42pmgimip2xmamhd.preview.jpg
IMAGE LINK: https://skitch.com/ren​edamkot/r68ce/canvas-size  (external link) Click for large view (external link)
Drag and drop the second image.
Reposition
Done.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
m.shalaby
May 08, 2011 14:38 as a reply to  @ René Damkot's post |  #3
awsome, thanks.
solara
May 09, 2011 01:37 |  #4
FYI, if you don't want to bother with having to open two or more files into separate workspaces, and then having to drag-n-drop them all into one workspace, you can use the File > Automate > Photomerge command.
Browse to the files and select them, and then de-select the "Blend Images Together" option. This will import the files into their own individual layers in one single workspace. If you are using CS5 and want the the Interactive User Interface that allows you to place the file that was available with previous versions of Photoshop, you can download the additional plugins here:
http://www.adobe.com …ads/detail.jsp?​ftpID=4688 (external link)
Probably not a huge time saver if you're just doing 2 files, but would save time using the Photomerge command without the blending option if you have several files you want to place or manipulate as separate layers.
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
René ­ Damkot
May 09, 2011 04:44 |  #5
File > Scripts > Load files into stack or
Bridge > Select images > Tools > Photoshop > Load files into PS layers...
would also work.
tristinGrind
Joined Jun 2010
May 11, 2011 17:04 |  #6
Use Comic Life and you can have all sorts of crazy layouts...
-- Tristin
FB: +12/-0
2,019 views & 0 likes for this thread, 4 members have posted to it.
2773 guests, 177 members online
