Has anyone used florescent studio lights ?
Does florescent light produce even light?
How does it compare to regular tungsten lights?
picard Goldmember 1,996 posts Likes: 1 Joined Jan 2006 Location: Canada More info | May 08, 2011 19:44 | #1 Has anyone used florescent studio lights ? Canon 1DM4,7D, Rebel XT
plasticmotif Goldmember 3,174 posts Likes: 2 Joined Sep 2008 Location: Tennessee More info | May 08, 2011 19:48 | #2 Yes. Mac P.
plasticmotif Goldmember 3,174 posts Likes: 2 Joined Sep 2008 Location: Tennessee More info | May 08, 2011 19:52 | #3 Heh. I've used a friend of a friends strip light 48" Flo bulbs x8 attached to a ballast which is then attached to a dolly to roll them around. The produce even lighting, sometimes. I always took several pictures in the same pose. Lemme see if I can dig up what the differences can look like between shots. Check the band. Mac P.
TheLostVertex Senior Member 520 posts Likes: 2 Joined May 2009 Location: Fl More info | May 08, 2011 19:52 | #4 |
RandyMN Goldmember 3,131 posts Likes: 2 Joined Aug 2005 More info | May 08, 2011 20:06 | #5 Used daylight balance for small subject work. Worked well.
May 08, 2011 20:09 | #6 plasticmotif wrote in post #12372543 Heh. I've used a friend of a friends strip light 48" Flo bulbs x8 attached to a ballast which is then attached to a dolly to roll them around. The produce even lighting, sometimes. I always took several pictures in the same pose. Lemme see if I can dig up what the differences can look like between shots. .5 second apart: Check the band. Wouldn't using 1/125' or 1/60' eliminate that?
May 08, 2011 20:26 | #7 hmm. it looks like florescent lighting is uneven Canon 1DM4,7D, Rebel XT
GwagDesigns Senior Member 299 posts Likes: 1 Joined Nov 2007 Location: Seattle, Washington More info | May 09, 2011 10:37 | #8 Depends how you use the light, You can pick up some flourecent work lights at home depot with bulbs for under $40 and achieve results like below:
[7D] - [GF1 w/14mm f2.5] - 70-200f4L | 50mm f1.2L | Sigma 10-20 | Sigma 105 f2.8 | Sigma 18-50 f2.8[U]
| Latest registered member was a spammer, and banned as such! 2539 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
