mikeisbeast wrote:
just take him out on a windy road and then lets see who will take it.. lol ahh good ole AWD
Despite what you hear in car commercials, AWD doesn't help you corner at all. Quite the opposite really, every production car that rolls off the assembly line understeers from the factory, which means that by trying to add power through the front wheels they will understeer even more (and they do).
Yes, AWD can be successful in racing, not because you hit the apex at a quicker speed, but because you can apply more throttle at the exit and get a jump on the guy next to you, but it adds weight, adds to parasitic power losses through the drivetrain, and tends to either induce torque-steer or reduce steering feel depending on how hard you boost the power steering (if there is any).
In a Viper vs Evo race on the street, stock for stock, with equal drivers (that's the real key here), the Viper would spank the Evo silly. REALLY silly. While the Viper is a "low-tech" American machine with "Oh my Gawd!" pushrods ... it makes more torque at idle than the Evo does ever. It has mountains of mechanical grip (is there a better kind? =) that come by way of the 275s out front and 335s out back. It has a lower center of gravity than the Evo, similar weight, significantly more power, torque, and area under the curve ... and as of the SRT-10, some of the best braking distances in the industry (mostly afforded through the aforementioned tons of mechanical grip).
The Viper is NOT the "straight-line" vehicle most assume it is. In fact, it is highly UN-desireable for drag racing with its low center of gravity and independent rear suspension (axle hop is a BAD thing).
For the record, I was a track instructor for two years.
Bill in Brooklyn
