Ross Murray wrote in post #12381513
Does it matter if it's 1 or 2?
I've got a glassless FD/EF adapter as this lens was bought with macro in mind (so infinity focus isn't essential)
Also, some of the Adaptall/EF adapters I've seen say "diaphragm control is set manually", which I don't quite understand. Does this mean there is something in the mount that depresses the linkage so whenever I turn the aperture ring, the diaphragm responds?
What it means is that the lens has no automatic aperture coupling, limiting you to stopped down usage only
When you use a normal SLR lens, its ALWAYS wide open when you're looking through the viewfinder, the lens only stops down to your picture taking aperture when you press the depth of field preview button or in the brief period of time you expose the imaging sensor
With one like this, when you set the lens to say, f/8, it stops down to f/8 unless you open it back up, this can make focusing/composing difficult as your viewfinder will be very dark (if you want an example, simply set one of your other lenses to f/8 and press your depth of field preview button)
