Thread started 10 May 2011 (Tuesday) 06:48
Gelling with Modifiers?
Peacefield
May 10, 2011 06:48 |  #1
I'm shooting a reception this weekend where there's going to be a lot of incandescent lighting which I'd rather use than over-power. In anticipation, I've picked up sheets of full and half CTO gel.
Typically, when shooting a reception, I'm either bouncing off the ceiling and using a large bounce card or I'm sometimes making use of a white shoot through or silver reflective umbrella. Does CTO gel behave the same way with these modifiers? Even the silver umbrella? Do I need to up the gel, meaning if I would normally use the half, I should use the full?
Thanks.
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
smorter
May 10, 2011 08:46 |  #2
Yes the CTO gels will work as normal. The modifiers change the amount and spread and direction of light but not the temperature (much). If it did, then changing flash power would also affect the colour of the flash (and I think it does but the change is so small its not noticeable)
This is based on my observation and not science
Wedding Photography Melbourneexternal link
Reviews: 85LII
pcj
May 10, 2011 12:53 |  #3
I frequently gel my flash when I put it in a softbox or even bounce it off white walls
7D (gripped) | GoPro Hero HD | Canon 70-200mm f/4 L | Tamron 28-75mm f/2.8 | 40mm f/2.8 | 85mm f/1.8 | 28mm f/1.8 | 3 * 600EX-RT - All gear
http://www.rt2photo.co​m (external link)
http://www.facebook.co​m/rt2photo (external link)
790 views & 0 likes for this thread, 3 members have posted to it.
1592 guests, 137 members online
