Thread started 10 May 2011 (Tuesday) 07:47
Set-up for formal prom pics-
wizard13
May 10, 2011 07:47 |  #1
Doing a favor for a friend at a small high schools prom. Using a pair of BXRI500's as the main lights and a 580exII and 430ex for background lighting with gels for school colors. Have either 45" umbrellas (shoot through or reflective) or 25" soft boxes to use. Any suggestions which would work better for the formal poses of either a couple or individual?
Thanks in advance.
Photography = a constant learning process
Website (external link) || Facebook (external link) || Gear/Feedback
Echo63
May 10, 2011 10:42 |  #2
When I was shooting formal school prom pics, we used a pair of monoblocks on stands, with reflective brollies.
I think that may have been more for the simple setup, and it was what the hire kits came with than any other reason.
More importantly, tape the cables, and the edges of the backdrop down properly, you don't want to get sued if someone trips on a loose cable
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
wizard13
May 10, 2011 10:46 |  #3
Echo63 wrote in post #12382717 (external link)
Thanks for the info. Was planning to tape all and will make sure now that you mentioned that.
Anything against soft boxes? Or just more the ease of set-up?
Echo63
May 10, 2011 20:12 as a reply to  @ wizard13's post |  #4
I personally have nothing against soft boxes, you may find they work better.
When I Was shooting school balls it was for a fairly large photographic studio, about half the gear we used was his, and the other half was rental gear.
The Bowens or Elinchrom rental gear would always arrive packed in a bag with brollies.
Brollies are faster and easier to set up, and much cheaper to replace if they get damaged, I feel that these are the reasons we were using them, instead of any image/light quality concerns.
We basically set up a backdrop (normally a fabric one, occasionally a roll of seamless)
2 lights, high and at 45 degree angles, metered to about f8
Shooting was done with cameras in the 6mp range, 10d and 20d etc and 28-135 type lenses.
wizard13
May 10, 2011 21:09 |  #5
Thanks for the info. That is what I was thinking when you mentioned umbrellas. Appreciate the lighting set-up. That is exactly what I am planning on doing.
Echo63 wrote in post #12386218 (external link)
RPCrowe
Joined Nov 2005
May 11, 2011 09:56 as a reply to  @ wizard13's post |  #6
All tape is not created equal...
I have to admit that duct tape is one of my favorite materials but, it certainly has its limitations. One of the downsides of duct tape is the sticky residue which often remains after the tape is removed.
That is not the fault of the manufacturer because, duct tape is designed to tape up HVAC ducting and not to be removed.
When a photographer wants to tape his electrical cords or tape anything else in which the tape must be removed, Gaffer's Tape is the material to use because it doesn't leave residue like duct tape does and because it is stronger and more adhesive than masking tape.
Gaffer's Tape is more expensive but, it is the right tool for the job...
http://www.uline.com …OH05p6U4KgCFQkF​bAodvFWfHg (external link)
Echo63
May 11, 2011 10:47 |  #7
RPCrowe wrote in post #12389165 (external link)
Yep, we used to go through rolls and rolls of Nashua 357 gaffa tape
Best stuff ever, I used it and a few cable ties to bodge the alternator bracket in my car together to get me home, 9 Months later I finally got around to fixing it properly.
One of my "rules" is "if you can't fix it with gaffa tape and cable ties, it's an electrical problem"
wizard13
May 11, 2011 12:00 |  #8
Echo63 wrote in post #12389476 (external link)
Love to see how you would fix a lens that was cracked in half with gaffa tape! Since that is not electrical-
2,928 views & 0 likes for this thread
Latest registered member is Jpcullen
983 guests, 246 members online
