Thread started 10 May 2011 (Tuesday) 14:44
studio light help
toadallymissy
Joined Jun 2010
May 10, 2011 14:44 |  #1
i have some cheap strobes that came with a cheap transmitter. sometimes they work great and others not at all they seem to recycle just fine but the transmitter seems to lose touch with them. what can i do to get them to always work. change the transmitter? if so to what?
Canon 7D, Canon Rebel T1i, EFS 55-250, Sigma 30mm, 85mm, EF 100 Macro , 100-400 L, EFS 18-135, EFS 17-55, 430EXII.
dedsen
May 10, 2011 15:59 |  #2
Without knowing what equipment you have is is hard to suggest anything other than make sure you have good batteries in the wireless transmitter and receiver. This is what the majority of the problems with reliability is.
toadallymissy
Joined Jun 2010
May 10, 2011 16:16 |  #3
This is what i have. i have extra lights though.
Still Shot 2 (TM) 2 SOFT LIGHTING BOXES: You will find 2 professional series lighting boxes conveniently stored away inside the free travel bag. Within a few minutes, it sets up nearly anywhere you desire. Each is constructed of a metal frame, outer matte black surface, inner highly reflective diffusion surface, and an optional soft white light diffuser. Each is designed to control light, hot spots, and shadows. Each box measures approximately 20x28".
Still Shot 2 (TM) SYNCH FLASH B (45w/sec): The synch flash will automatically flash when either of the other strobes fires. It is an excellent photographers tool for fill or back lighting. When used in conjuction with the gold umbrella supplied, it will provide a soft glow to the photography subject. The synch flash also includes a hands free adjustable umbrella holder to allow precision soft glow.
Still Shot 2 (TM) Gold Umbrella: Designed to connect to the synch flash stand (mentioned/ pictured above). It's purpose is to provide a soft uniform glow to the photoghaphed subject.
Still Shot 2 (TM) 2 Professional Studio Strobe Lights: If you recently have shopped at your local photography store, then you probably know the retail price of only 1 light is easily $150! Each light is constructed of the highest quality materials to ensure a long life. Each light boasts 160 watts of power per second! The combined 320 watts are fully adjustable when less light is required by simply turning a knob. Many professionals use the strobes for a variety of purposes; such as, back light, fill light, primary light, or even hair light. This lighting set is a key ingredient for any prefessional still shot.
Still Shot 2 (TM) 3 Lightweight Fully Adjustable Aluminum Light Stands: 2 matching stands that range in height from 37-84" and a third stand that extends 18-39". Each collapses into a compact and easily transportable size- tucks away into the storage bag. All 3 stands are very stable providing a wide stance. They each are constructed of a heavy duty lightweight aluminum with riveted joints and reinforced brace supports.
Still Shot 2 (TM) Reflector: 1 22" (56cm) Gold & Silver (double sided) collapsible reflector. Free storage bag included. Another tool for the professional photographer.
Still Shot 2 (TM) 1 four Leaf Barn Door, 4 gels, 1 honeycomb, and 1 snoot attachment: The barn door purpose is to help control light spill. It easily attaches to the strobe head. Constructed of metal with 4 hinged adjustable flaps. There are 4 gel color (red, blue, white, and yellow) attachments for correcting/ adjusting the light balance or to create lighting effects. The honeycomb grid is designed to emit a precisely positioned beam of light. And finally the snoot attachment prevents spill over light. click image for a brief description or double click to expand
Still Shot 2 (TM) 1 Remote Sync Transmitter: This remote will tie all the lights together to syncronize each flash at once. The receiver will connect to one of the strobe lights and activates all flashes at once when the signal is received. Each strobe also includes a built-in slave sensor that is designed to activate with the primary strobe. The remote wireless transmitter mounts onto the hotshoe of your camera (auxillary flash mount). Everytime you snap a photo, all strobes will fire automatically. It works will nearly all 35mm SLR cameras. Each remote has 2 channels.
707 views & 0 likes for this thread, 2 members have posted to it.
studio light help
2539 guests, 155 members online
