Has anyone been succesful in getting this to fire while connected to a Cactus V5.
Here's my setup:
- Quadra Ranger battery connected via sync cord with a Cactus V5 transceiver (set to Channel 1 & Tx mode (transmit mode))
- Quantum Trio on shoe of transceiver (set to Channel 1 & Rx (receive mode)); the Trio does not have a sync port to connect directly to the transceiver.
- Go into menu system on Trio and set the radio options, i.e. turn on all four zones, set to channel 1 & Rx (receive)
My thought process was that the transceiver that's attached to the Quadra battery would send a signal to the transceiver on the Trio and it would also fire.
Does anyone else have this setup working?
