Thread started 13 May 2011 (Friday) 01:22
7d battery/charger issue
javig999
May 13, 2011 01:22 |  #1
Plugged in the Canon charger for my LPE6 batteries as I have many times before. I charged the lower level of the two batteries (21%) and as usual the indicator light blinked once per second. After a few seconds it started to blink very rapidly and at a constant rate. Took it off the charger and popped it back on....same thing.
Popped other battery on and it worked normally.
Both are original Canon batteries. The grip is a Zeikos. Noticed that one battery drains much more quickly than the other. Is this normal in a gripped 7D? Today one battery was at 21% and the other at 63%. Should they be staying closer together?
Bad battery?
7D | 8mm 3.5 FE | EF-S 10-22 | EF-S 17-55 2.8 IS | EX DC 30 1.4
EOS R | Samyang 14 2.8 | Sigma 15mm f2.8 DFE | RF 16mm | Art 20/35/50/85 f1.4 | EF 100 f2.8 Macro | EF 135 f2L | EF 70-200 f2.8L IS | Sigma C 150-600
NinetyEight
"Banned for life"
May 13, 2011 05:20 |  #2
I'm sure the grip alternates between the highest charged battery so in theory they should discharge at the same rate together.
Sounds like on has gone faulty.
Just use one battery at a time and compare how they discharge. If one does not charge properly this indicates a faulty unit.
Kev
pdrober2
Joined Nov 2010
May 13, 2011 06:38 |  #3
You're sure it's original? Alot of the ones on eBay from china are 3rd party even though they come in a canon box with near- identical build.
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
philwillmedia
May 13, 2011 07:43 |  #4
javig999 wrote in post #12400756 (external link)
have you read the manual?
This appears to be normal.
According to page 24 of the 7D owners manual the following occurs.
if the battery...
has a charge level of 0-50% the charge lamp will be orange and blink once per second
has a charge level of 50-75% the charge lamp will be orange and blinks twice per second
has a charge level of 75% or higher, the charge lamp will be orange and blinks three times per second.
When fully charged, the light goes green and remains on.
and from the canon website http://support-au.canon.com.au …nts/AU/EN/82005​96900.html (external link)
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
javig999
May 13, 2011 09:00 as a reply to  @ philwillmedia's post |  #5
Thanks alll...
Did look at the manual. The blinking of the lamp is different from when the battery is charging normally. The stages indicated will usually have a "pause" inbetween the blinking patterns, for example: blink-blink-blink...pause. blink-blink-blink...pause. The current pattern is just a constant blink like 4 times per second.
I thought all was original. Suppose I could have gotten a fake...
javig999
May 13, 2011 09:51 as a reply to  @ javig999's post |  #6
Popped it in again after the other battery charged overnight...works normally...hopefully the charger is not taking a dump...
Thanks again...
5,103 views & 0 likes for this thread, 4 members have posted to it.
974 guests, 108 members online
