Thread started 13 May 2011 (Friday) 06:52
Lightroom color shift between Develop and Library
pknight
Gallery: 39 photos
Joined Feb 2006
May 13, 2011 06:52 |  #1
I have been having a problem with making adjustments to an unusual image in Lightroom. The image is a close-up of a red(ish) piece of stained glass. I have taken it into the Develop module of LR3 and adjusted the color balance to make it more purely red. When I return to the Library module, the color of the image looks like it did in Develop for about a half second, and then it turns orange(ish). I have tried adjusting the color in PS-CS5, and the same thing happens when I import the image back into LR.
I have never noticed this with an image before. Any ideas what is going on here?
Thanks.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
tzalman
Fatal attraction.
May 13, 2011 08:25 |  #2
LR makes two preview files for every image, one for the Library and one for the Develop module. They should look pretty similar (although they are in different color spaces), but if they don't one possible explanation is that there is a problem with your color management - a monitor profile that LR is having problems reading or your OS default being set to sRGB.
However, there are other possibilities; like LR simply not revising the Library profile to sync it to the Develop settings. There are ways to force LR to rerender the preview, such as enlarging it to 1:1 and then reducing it back to 'Fit' or 'Fill'. There is also a menu command to render previews, but since I am not at home now I won't be able to help further until later.
Elie / אלי
1,583 views & 0 likes for this thread, 2 members have posted to it.
1596 guests, 139 members online
