Thread started 09 Oct 2005 (Sunday) 11:45
Chromatic Aberration - 17-40 vs Primes
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Oct 09, 2005 11:45 |  #1
I've got a 17-40 f/4 L and I've been unhappy with Chromatic Aberration I've seen with this lens. I'm wondering if anyone else has converted from the zoom to a prime and seen a change in CA - slight reduction, huge reduction...?
Here's an example, @17mm f/8:
IMAGE: http://www.itsanadventure.com/postimages/17-40CA.jpg
Another similar example to compare, Tamron 28-75 @ 28, f/8:
IMAGE: http://www.itsanadventure.com/postimages/28-75CA.jpg
I don't find the Tamron to be as objectionable, though the CA is close. The leaves might not be a fair comparison since they were further from the bridge and not quite in focus.
Now, I know this is a worst-case situation, tree branches against a bright featureless background. I know I could have fixed this (to some extent) with ACR. I know that avoiding the situation is the best thing. I know that this is not a fair test - it's not, it's just a comparison of a couple shots I happen to have available. I know primes should be better, but my questions are:
How Much Better?
Am I Being Unreasonable?
Does anyone have any comparable examples from any of the cheaper primes?
Because of this CA the f/4 of the 17-40 I'm debating going to a prime or two or three. I quickly checked B&H and found a number of primes for $420 and lower. I'd be inclined towards the Canon 20mm f/2.8 - a lens which is plenty wide enough for me and I won't miss the extra 3mm, and I will enjoy the wider aperture. Any idea how any of these lenses compare to the quality and CA of the 17-40?
Any comments in general about these thoughts?
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
DocFrankenstein
Joined Apr 2004
Oct 09, 2005 12:28 |  #2
From what I've seen, tokina (or was it tamron? ) 17mm doesn't have that problem.
Was that shot wide open?
National Sarcasm Society. Like we need your support.
Scottes
Joined Nov 2003
Oct 09, 2005 12:30 |  #3
As stated, both shots were the widest the lenses could do, and both were at f/8.
PacAce
Joined Feb 2003
Oct 09, 2005 13:43 |  #4
Scott, could it be possible that you have a bad copy of that lens. I find it hard to believe that you could get such bad CA with an L lens. I have a Sigma 17-35 EX and CA isn't as bad on it as it looks on yours. AAMOF, CA isn't even really noticeble until I zoom in 300 or 400%. Was your sample a 100% crop or was it maginified more than that?
...Leo
cmM
Joined Apr 2004
Oct 09, 2005 14:03 |  #5
You know I haven't seen very much CA in the pictures with my 17-40.
I'll take it out for a spin today take some test shots for you and post them, I am tempted to assume you have a bad copy.
But then again, you are bound to have SOME in a high contrast scene as above.
Cadwell
Joined Jan 2004
Oct 09, 2005 14:17 as a reply to  @ cmM's post |  #6
Mmmm.... I prefer to use my 17-40L over the 24mm f/1.4L where light allows because the 17-40L shows LESS CA. Based on that, I'm surprised your 17-40L is showing so much.... in fact I can't recall CA ever being an issue with my 17-40L.
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 09, 2005 15:06 |  #7
Likewise,. I have not felt at all aware of too much CA on my 17-40mm either.. (granted I've never done any testing)
It might be time for a trip to Canon?
CDS' HOT LINKS
Scottes
Joined Nov 2003
Oct 09, 2005 16:12 |  #8
Ooops. I forgot to mention that both shots are crops zoomed to 200%.
But it sounds like I should be seeing less CA with this lens. Anyone have an example of their 17-40 with a scene that should show CA?
I may have to do a real test run and compare it to my Tamron and nifty 50 (only short prime I have). CDS, maybe next time we meet could you bring your 17-40 and I'll compare both with an identical shot?
cmM
Joined Apr 2004
Oct 09, 2005 23:25 as a reply to  @ Scottes's post |  #9
Okay, I took a couple test shots to see how it acts.
17mm f/4.0 , backlit tree:
17mm f/8.0, same backlit tree:
BTW, both are 200% crops.
J ­ Rabin
Joined Aug 2004
Oct 09, 2005 23:34 as a reply to  @ cmM's post |  #10
I'm a little confused.
1. How does one tell the difference between CA and the "dreaded digital sensor purple fringing bloom on high contrast over exposed edges" phenomenon? Is there are difference?
2. Don't all wide angle lenses have some CA if asked to perform taking pictures of high contrast over exposed details?
Jack
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 09, 2005 23:41 |  #11
1. I don't know. But given that the sample images look to have blown out skys,. it may very well be purple fringing... ? Right?
2. Yes..
But we've certainly seen cases where someone has a "bad" copy of a lens that shows much more CA than others...
CDS' HOT LINKS
Cadwell
Joined Jan 2004
Oct 10, 2005 00:49 as a reply to  @ J Rabin's post |  #12
Jack
If it's genuine CA it will tend to have red-ish fringing on one side the blue-ish fringing on the other as seen in Scottes posts...
Glenn
pcasciola
POTN SHOPKEEPER
Joined Sep 2004
Oct 10, 2005 00:58 as a reply to  @ Cadwell's post |  #13
I can't for the life of me find the post now, but WAY back someone here did a comparison between the 10-22 and 17-40L, and I remember him saying the CA and lens flare were problems on his 17-40L. Not saying the 10-22 is a better lens, but just making reference to another person claiming CA problems with the 17-40L. If I remember correctly, he had posted some sample landscape shots up on pbase.
Philip Casciola
Pro Camera Gear (external link) - POTN Shop (external link)
Canon 7D, EF 50/1.8, EF 85/1.8, EF 300/4L IS, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
Cadwell
Joined Jan 2004
Oct 10, 2005 01:13 as a reply to  @ pcasciola's post |  #14
May just have been out of whack. When my 100-400L came back the first time after having its IS repaired it displayed a lot of CA. After being returned to Canon twice more for "recalibration" the lens is fine. I guess that can be a peril of drawing conclusions about a lens from a single sample. When a lens is produced in large quantities like the 17-40L there are bound to be some not-so-good copies out there.
Glenn
munchy
Oct 10, 2005 02:19 |  #15
So 'purple' fringing means it's to do with the sensor and 'red on one side, blue on the other' means a not so good lens...
Hmmm, I just purchased a 17-40, will have to do a similar test when I get home to check this out.
7,813 views & 0 likes for this thread, 9 members have posted to it.
1682 guests, 137 members online
