I like to use my external light meter as much as possible to dial in the best expose using my 7D + 580EX II Speedlight. However I have found myself in situations where the lighting situation might suddenly change and I dont have time to take a new meter setting.
I find myself fumbling to quickly transition from External mettering on my flash to ETTL mode.
Perhaps I have missed someting but is there any possible way to set up my camera or flash so I can quickly transition from Extenral Metering to to ETTL.
I thought I might be able to do it with using the Custom Settings on my camera but it turns out that the external flash settings on the camera will not be associated with a profile.
.. Switching to full automatic Mode on the camera will automatically switch flash to ETTL modde.. but I don't use any of the automatic settings. The only settings I use on my camera anymore is Manual and BULB, once in a while Tv.. the rest are uneeded.
) the light->subject distance will not change. Once the flash is ON camera, E-TTL works much better.
