I just installed CS5 (upgraded from CS3) and noticed my Noiseware and Viveza plug-ins aren't inlcluded in the CS5 program---anyone know if I can import them from 3?
May 13, 2011 17:25 | #1 I just installed CS5 (upgraded from CS3) and noticed my Noiseware and Viveza plug-ins aren't inlcluded in the CS5 program---anyone know if I can import them from 3?
Merlin_AZ Senior Member 872 posts Likes: 17 Joined Mar 2010 More info | May 13, 2011 17:59 | #2 You can either uninstall the plugins and reinstall them, choosing CS5 when it asks where to put them.
S.Horton worship my useful and insightful comments More info | May 13, 2011 18:20 | #3 I had to upgrade all of my add ins after doing that exact upgrade. Sam - TF Says Ishmael
May 13, 2011 20:34 | #4 S.Horton wrote in post #12405197 I had to upgrade all of my add ins after doing that exact upgrade. That's what I was suspecting! Thanks====
S.Horton worship my useful and insightful comments More info | May 13, 2011 20:45 | #5 Welcs. Upgrading was nice but some actions need to be tweaked if the add ins are used. Sam - TF Says Ishmael
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | May 13, 2011 21:02 | #6 Even though you upgraded from CS3 to CS5, they do not share the same directories. You now have two versions of Photoshop Installed on your computer. If you have any plugins or ATN's that you want from CS3 you will have to copy or move them into the correct directory in the CS5 Directory tree.. E.g. if you're on a Windows PC it would be something like -> C:\Program Files\Adobe\Adobe Photoshop CS5\Plugins. Tim Kerr
ThomasOwenM Senior Member 959 posts Likes: 1 Joined Mar 2007 Location: Boise, Idaho More info | I've had the same frustrating problem with Silver Efex Pro. I copied it over from CS 3's plugin folder and definitely put it in the right one in CS 5. In CS 5 Silver Efex comes up in the menu and even runs when I choose it, but the changes don't go into effect. My other plugins, which I also simply copied over appear to work fine. ===============
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | May 13, 2011 21:46 | #8 Don't forget to check out the Goodies Folder on your installation CD's Tim Kerr
| Latest registered member was a spammer, and banned as such! 2773 guests, 177 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
