Thread started 13 May 2011 (Friday) 23:52
Some 7D Questions
Cr4zYH3aD
May 13, 2011 23:52 |  #1
1) How and when should I use AE Lock ?
2) Should I disable the "Auto lightning optimizer" ? Now it's set to "strong" but in the manuel it says that it can increase noises.
3) Should I use "Landscape" instead of "Standard" in User-Def Picture Style ? It boost greens, blues, and is sharper and crispier than Standard (from the manual), I don't want the pictures to be unbalanced (And sharpness is already to +7)
4) Should I turn the High Iso Noise Reduction to Off or reduce the strenght ? (can't remember where it is)
5) How can I make HDR Picture from AEB ? (Do I have to merge them in a software ?)
6) I'm using AV w/ F/2.8. Should I use Auto ISO, or try to find the right one ? It's convenient but, I don't know if it will put iso sky-high for nothing (like in Point&Shoot Cameras)
Thanks!
Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
May 13, 2011 23:55 |  #2
1) Uh... that depends... (maybe someone can give a more elaborate answer on situations)
2) I have it off. I also have highlight tone priority off as well.
3) This only matters when you're shooting in *.jpg. Shoot in RAW and you can pic whatever style you want later with DPP (and other RAW converter/editor).
4) Again, this only matters if you're shooting in *.jpg. Shoot in RAW and you can adjust noise reduction in DPP (and other RAW converter/editor).
5) You will need a photo-editing software that will allow you to merge/process them on your laptop/desktop.
Julian
Cr4zYH3aD
May 14, 2011 00:06 |  #3
Thanks. I thought that the sharpness and noise NR affected RAW files, my Raws were noisier, so I have to apply NR from a software then !
jwcdds
Best ofs: 8
Joined Aug 2004
May 14, 2011 00:10 |  #4
It only affects RAW files if you open up with DPP. Canon will take the settings you set on the camera and apply the effects (reversible) on screen. You can still go into the menus/tools in DPP to change/alter the files (change picture style, WB, sharpening, etc...) before you convert it to *.jpg (or whatever you want to export as).
Julian
Sdiver2489
Joined Sep 2009
May 14, 2011 00:20 |  #5
+7 sharpness is IMO too high
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
RobDickinson
Gallery: 14 photos
May 14, 2011 00:44 |  #6
When you want to expose for something but point the camera somewhere else!
Say select center weighted, point it at a person, lock the exposure, then shift so the sun is in the frame. Otherwise the camera would meeter for the sun and under expose the person.
I dont use it with raw sorry, prolly have it off.
I shoot raw and have my picture styelset to neutral with -4 contrast, this gives a more accurate histograme (which is a jpg processed with the picture style even for raw!)
Depends if your going to do NR in software later.
Photomatix or CS5 etc.
I use Auto ISO when light is iffy for shutter speed and is changing. I'd rather a nosier photo than one with blur. One is easy to fix with software...
www.HeroWorkshops.com (external link) - www.rjd.co.nz (external link) - www.zarphag.com (external link)
Gear: A7r, 6D, Irix 15mmf2.4 , canon 16-35f4L, Canon 24mm TS-E f3.5 mk2, Sigma 50mm art, 70-200f2.8L, 400L. Lee filters, iOptron IPano, Emotimo TB3, Markins, Feisol, Novoflex, Sirui. etc.
1,495 views & 0 likes for this thread, 4 members have posted to it.
Some 7D Questions
1857 guests, 151 members online
