So, this seems like a weird question, but does exposure affect White Balance?
For example, I picked up a Lastolite EzyBalance card...do I need to set my exposure BEFORE taking the WB reference shot off of it? Or does it not matter?
Thanks!
Snydremark my very own Lightrules moment More info | May 14, 2011 17:56 | #1 So, this seems like a weird question, but does exposure affect White Balance? - Eric S.: My Birds/Wildlife
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 14, 2011 18:03 | #2 |
May 14, 2011 18:06 | #3 Yes...should have been more clear. - Eric S.: My Birds/Wildlife
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 14, 2011 18:23 | #4 Well, it does appear to matter that you must exposure the WB target accurately. I checked my camera manuals and they all say either under- or over-exposure may affect the accuracy of the white balance.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | May 14, 2011 18:36 | #5 If you choose the WB eyedropper in LR, it's more accurate on white then on dark gray. "I think the idea of art kills creativity" - Douglas Adams
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 14, 2011 18:45 | #6 PixelMagic wrote in post #12410186 Well, it does appear to matter that you must exposure the WB target accurately. I checked my camera manuals and they all say either under- or over-exposure may affect the accuracy of the white balance. Here's what my 1D Mark III manual says, for example: "Shoot the white object so that a standard (gray) exposure is obtained. If it is underexposed or overexposed, a correct white balance may not be obtained." I think that is Canon covering their collective butt lest somebody over or under expose to the point of clipping. As René says, a card exposed ETTR without clipping should have the advantage of more photo data and less noise. Elie / אלי
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 14, 2011 19:00 | #7 All true...the same advice regarding correct exposure in in my ColorChecker Passport manual. I'm thinking along the lines of blowing the red channel through overexposure, for example, could fool the camera into calculating an incorrect WB. René Damkot wrote in post #12410244 If you choose the WB eyedropper in LR, it's more accurate on white then on dark gray. If you first WB, then adjust exposure, you might get a hue shift, depending on the DNG profile you use: http://dcptool.sourceforge.net/Hue%20Twists.html Apart from that: AFAIK, It doesn't matter. You can WB on a white (not blown!) or a dark gray piece of paper. And that is regardless of the actual 'brightness' of the paper ![]() No matter what the manual says, I usually expose a gray / white paper "well" (middle gray or about a stop above), and use that for CWB. Never had problems. Then again, I usually re-do it in the Raw converter... tzalman wrote in post #12410286 I think that is Canon covering their collective butt lest somebody over or under expose to the point of clipping. As René says, a card exposed ETTR without clipping should have the advantage of more photo data and less noise.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 14, 2011 19:16 | #8 I've always wondered whether when making a CWB the camera uses RAW data - which would seem to be indicated by the fact that you can photograph the target card with any WB set, or whether it uses rendered (jpg) data - which would seem to be indicated by the instruction that you can use any Picture Style except B/W. If it uses the RAW data, the chances of a blown red channel are reduced but you could blow the green alone. Elie / אלי
May 14, 2011 19:35 | #9 Thanks, folks! - Eric S.: My Birds/Wildlife
tonylong ...winded More info | May 14, 2011 20:38 | #10 tzalman wrote in post #12410439 I've always wondered whether when making a CWB the camera uses RAW data - which would seem to be indicated by the fact that you can photograph the target card with any WB set, or whether it uses rendered (jpg) data - which would seem to be indicated by the instruction that you can use any Picture Style except B/W. If it uses the RAW data, the chances of a blown red channel are reduced but you could blow the green alone. Hmm, interesting question -- I guess it would either use the jpeg rendering of the target or else calculate as it is interpreting and rendering the jpeg, either way I guess would work but I don't have a clue as to how it actually works Tony
| Latest registered member was a spammer, and banned as such! 2585 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
