Thread started 15 May 2011 (Sunday) 02:40
B+W ND/Polarizing Filters?
BzBrian
Joined Apr 2011
May 15, 2011 02:40 |  #1
I'm quite new to special effect filters so I'm thinking about getting both a B+W ND filter and a B+W CPL filter on my Canon 10-22mm UWA.
First, do I need the 1.8 (6 stop ND) or the 3.0 (10 stop ND) filter to get the silky water effect? Also would a GND filter be more useful than a ND filter for landscapes overall?
Second, do I need to get a B+W Slim 77mm CPL filter for my 10-22mm? Also if I used the same polarizer on another lens like the 70-200mm would the slim filter be ok?
Thanks.
I'm a happy Canon SLR and Leica rangefinder user. bw!
argyle
May 15, 2011 06:59 |  #2
1.) The strength of the filter for getting the "silky" effect depends on the amount of light available, as well as how fast the water is moving (not to mention your chosen exposure settings of ISO and aperture). In some cases, you may not even need an ND filter to get the desired effect. In my experience, you need to get down to a shutter speed of 1/2-second and longer to start seeing the silky effect. The higher the ISO and/or the larger the aperture, the more ND you'd need. The opposite holds true for the converse. THe B+W polarizer will also give you about two full stops of ND reduction in addition to its polarizing effects (it can also be stacked with an ND filter for additional light reduction in addition to polarization). If you could swing it, I'd recommend getting two ND filters...a 3-stop and a 6-stop...with the polarizer, you'll have quite few possible combinations and you'll be covered for most situations. Just need to be mindful of vignetting at wide apertures when stacking filters. The 10-stop is a great filter, but if that's your only filter, you'll be somewhat limited IMO.
2.) A GND is used to balance the exposure between a brightly lit sky and a darker foreground. An ND filter can't do what a GND filter can. Both filters have their place in landscape shooting, but their use depends on the scene, the conditions, and the result that you're after. They can also be combined/stacked. Stay away from the round screw-in GND filters...
3.) You don't need the slim B+W for that lens...the B+W F-Pro model will work just fine without vignetting.
Pi_314
May 15, 2011 11:36 |  #3
I went with this variable ND filter. Two to eight stops
http://www.bhphotovide​o.com …_ND_Variable_Ne​utral.html (external link)
The price is hard to swallow, thusly I chewed on it for a while. In the end it went down easy once I got a taste of it. It's a joy to use. Vignetting is a problem and I don't know what that would be on you camera. I'm assuming you do not have a full frame. You might consider a larger size filter if you intend to stack. Much depends on what you have in terms of lens choice.
argyle
May 15, 2011 11:55 |  #4
Pi_314 wrote in post #12413320 (external link)
I also use the Vari-N-Duo...variable ND with an integral polarizer. When you factor in the price of multiple quality ND filters, as well as the price of a quality polarizer, the Singh Ray price is pretty much a wash.
Pi_314
May 15, 2011 12:29 |  #5
argyle wrote in post #12413438 (external link)
I looked seriously at tha one you bought, but ended up taking a pass, because I thought that I might fall into a situation where I'd want them seperated. Although I might kick myself somewhere along the line, as stacking will entail a bit more vignetting than the one you bought.
Gonna get these possibly today to complete the filter buying for now. The prices are real killers,,,,,,,,,,,, aren't they?
http://www.bhphotovide​o.com …_Circular_Polar​izing.html (external link)
http://www.bhphotovide​o.com …ated_Neutral_De​nsity.html (external link)
Question - Is a two stop gradual ND the best choice over a one or three stop?
ben_r_
-POTN's Three legged Support-
May 15, 2011 14:25 |  #6
Depending on how bright your ambient light it, yes an ND filter will help you get those silky smooth water effects.
And no, you will not need the slim B+W filter for your 10-22. As long as you get the B+W F-Pro version, youll be fine.
argyle
May 15, 2011 14:28 |  #7
Pi_314 wrote in post #12413658 (external link)
Unless I happen to be getting a filter from Singh-Ray, I only use B+W filters and all of them from this link...excellent prices, but if you're willing to wait for delivery from HK (not too bad) you can save yourself some money:
Maxsaver (external link)
Can't say for sure which GND I use more...the 2 or 3, for me its probably an even split. I have a 1-stop, but this I haven't used at all (so far).
Mark-B
May 15, 2011 16:47 |  #8
As already stated, there are a lot of variables that play into this. The amount of available light will determine how long your shutter is open, and the speed of the water movement during that time will greatly affect the amount of blur you get.
I use the 6 stop filter with my 10-20. In the middle of a bright sunny day, I might be able to get a 2 second exposure if I stop all the way down to f/22. Under the same conditions, a 10 stop filter would give me a 30 second exposure. If I were somewhere under trees or in the shade, those shutter speeds would get considerably longer. Depending on how fast the water is moving, anywhere from about 1/20 or longer should give you some amount of blur.
Mark-B
msbphoto.comexternal link
hollis_f
May 16, 2011 04:22 |  #9
I've tried a couple of cheap versions and they give a horrible cross-pattern when used with the 10-22 at medium strength. Is the Singh-Ray better?
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
ottacat
May 16, 2011 06:51 |  #10
Try to work somewhere between 4-7 stops reduction between your combination of ND's and CPL. Your 7D's live view can still see through that much and allow effective composition. At 10 stops your live view can no longer see through and you have to switch to the 'compose, meter + add filter + manually adjust exposure time + shoot mode'. I personally find the blur I'm looking for starts at the 2 second range.
I have a 2 stop ND, a 3 stop ND plus a CPL. I don't tend to shoot waterfalls much with my 10-22 but rather my 17-55 so vignetting isn't an issue with stacking filters. If I bought again I'd get a 3 stop and a 4 stop.
There are several waterfall shots in the most recent 10 shots my Flickr photostream and I list my combination of filters in the description and make the exif data available. It will give you some visible examples of shutter speed vs. blur. I also have one with a Lee Big Stopper which shows the very different effect you start getting a very long shutter speeds.
7D, EF-S 10-22, EF-S 17-55, EF 70-200L IS II, EF 100 macro, 1.4 TC III, 430 EX II
Sdiver2489
Joined Sep 2009
May 16, 2011 07:20 |  #11
ottacat wrote in post #12418132 (external link)
Not true, I use live view all the time through my 10 stop B+W filter. It works fine, including autofocus(contrast detect)..
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
Marcy
May 16, 2011 09:18 |  #12
with the 10-22 lens I found that any polarizer over did the shot so I rarely use it on that lens but I use it on my 24-105 the B+H is a really nice one -
Pi_314
May 16, 2011 10:05 |  #13
hollis_f wrote in post #12417864 (external link)
Can't say I have a boatload of experience with ND filters, as this is the first one I have ever owned, and I've only owned this filter for a few days. Used a 24-70 lens the first day, and had no problem with a cross pattern at 24mm. Thats the only information I can give you in this regard.
I do have some experience on buying cheap stuff though. :D
And that is to pick your battles wisely, like battery grips can be had on the cheap, without losing the war. I'm quite happy with my cheap assed version. All I can say is read up well on your opponent, before taking up the sword, lest you perform hari cari in the end. I spent several days reading up on variable neutrals before going in for the kill, and so far I'm without a scratch.
I can say witout question that I got burned financially with the price of the Singh-Ray, the mark-up has to be bordering on extreme, but in all likelyhood they deliver on their claims, which lessens the thought that you have been mugged. bw!
argyle
May 16, 2011 12:21 |  #14
That's probably not accurate...with my 5D2, LV has no problem seeing through 12-stops of light reduction (10-stop + polarizer) in somewhat decent/borderline light. I would imagine the LV on the 7D would be no different...
hollis_f
May 16, 2011 12:47 |  #15
argyle wrote in post #12419891 (external link)
It's not. Just tried it with Heliopan 10-stop ND and it works fine.
6,563 views & 0 likes for this thread
Latest registered member is vini81
707 guests, 278 members online
