Hi guys,
Just came back from my trip, imported my pictures to LR to find most of them like this.
Is this a fault of my sd card or gpu?
Has anyone experianced anything like this before?
What's your advice?
tommmy.star Senior Member 294 posts Joined Sep 2010 Location: london More info | May 15, 2011 14:56 | #1 Hi guys, Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
NinetyEight "Banned for life" More info | May 15, 2011 15:03 | #2 How are you importing them, with a usb cable or a card reader? Kev
gjl711 Wait.. you can't unkill your own kill. 57,730 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | May 15, 2011 15:03 | #3 I've seen this twice. Once it turned out to be card related and the other time PC related. The card issue was a Lexar card. I had no issues with the card in my Nikon, but two different Canon cameras had the problem. I was never able to recover the images. Not sure why, but call me JJ.
Snydremark my very own Lightrules moment More info | May 15, 2011 15:05 | #4 Looks like data corruption on the card or in the transfer process to me. If you view the images on the camera's LCD, do they look like this, as well? - Eric S.: My Birds/Wildlife
Ok, Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
OOOOOOOOOOOOHH NOOOOOOOO!!! Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
This must be a nightmare! Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
NinetyEight "Banned for life" More info | May 15, 2011 15:31 | #8 Use a card reader and/or a different USB cable Kev
Snydremark my very own Lightrules moment More info | May 15, 2011 15:44 | #9 I suspect you may need to either A) format your current card or B) get a new card. If they're copying over corrupted, they're likely getting stored badly. - Eric S.: My Birds/Wildlife
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 15, 2011 16:14 | #10 Whenever I've seen this before it usually indicates that a hard drive is failing. If I were you I'd go out and get a new drive and back up the current one immediately.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 15, 2011 16:17 | #11 tommmy.star wrote in post #12414543 This must be a nightmare! When I look at them in a GRID VIEW they're getting 'infected' as I'm viewing them. I have seen many cases where the embedded jpg was ok although the RAW data was corrupt. The camera's LCD review looks good because it uses the jpg and the first display in LR is also the jpg until it is replaced after a couple seconds by LR's conversion from the RAW. If that conversion is affected it's a sign the RAW data is corrupt. Most likely perp, the card. Elie / אלי
May 15, 2011 16:19 | #12 PixelMagic wrote in post #12414788 Whenever I've seen this before it usually indicates that a hard drive is failing. If I were you I'd go out and get a new drive and back up the current one immediately. Well, don't know what to think. Hard drive failure? that would be really unlucky as this 's happened on both drives I have. Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 15, 2011 16:26 | #13 If its happening with photos on more than one drive its unlikely to be a problem with the drives.
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | May 15, 2011 16:52 | #14 Have you tried a new memory card? if you did, does the problem persist? Tim Kerr
tonylong ...winded More info | May 15, 2011 22:50 | #15 I'll try to put into a nutshell the most-often causes: Tony
| Latest registered member is RawBytes 1360 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
