Thread started 16 May 2011 (Monday) 06:42
Sekonic Wireless Transmitter problems???
BaghdadFred
Joined Nov 2010
May 16, 2011 06:42 |  #1
I bought the wireless transmitter module for the Sekonic L-358. Instructions simply tell you to plug in the module. Switch to wireless mode and then pick the correct channel (1-32) on your meter. On my 580EX II I am able to select from channels 1-4 and put it in wireless mode.
The metter simply sits there flashing the channel number. The two devices don't appeart to be communicating.
I know there are two wireless modes.. On the back of my meter it says "Use RT-32N" FOR radio transmitter module and thats the module I purchase.
Any idea what might be the problem? Bad module perhaps???
Fred - Photographing everyday Military life in Iraq (external link) | SmugMug (external link)
7D | C 100-400L | Σ 70-200 2.8 OS | Σ 30 1.4 | C 10-22 | Σ 8-16 | C 17-55 2.8 IS | C 28-135 IS | 580EX II | Σ 1.4x
Matthew ­ Patrick
May 16, 2011 06:49 |  #2
What are you using to trigger the 580 EX II? Do you have some Pocket Wizards? The meter will not trigger the 580 directly, but it will trigger a Pocket Wizard that will in turn trigger the strobe.
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
May 16, 2011 07:12 |  #3
Woops.. looks like you didn't do enough research on that one, I'm afraid. :( RT-32 module is for PocketWizards. There is no transmitter for any speedlite, regardless of brand / manufacturer.
[ www (external link)· flickr (external link)]
windpig
Chopped liver
May 16, 2011 08:07 |  #4
What kind of metering are you planning on doing? Do you have a wireless shutter release?
Go ahead, spin the wheel.
TMR ­ Design
Joined Feb 2006
May 16, 2011 08:13 as a reply to  @ windpig's post |  #5
The only way a Sekonic Pocket Wizard transmitter module works is if it's talking to another Pocket Wizard. It can't communicate with any other system or brand of triggers or flash units with IR wireless modes.
To trigger your Speedlight via a Pocket Wizard you need a PW Multi-Max, Plus II, Plus, or FlexTT5.
Robert
BaghdadFred
Joined Nov 2010
May 16, 2011 09:10 |  #6
I love my sekonic but wow what a racket.. you can easily spend 300 dollars on a pocket wizard set up. I wonder if I should return my IR Wireless Module or if I can find a use for it later...
For under 30 bucks I'll just use my wireless remote for the time being.
TMR ­ Design
Joined Feb 2006
May 16, 2011 09:17 as a reply to  @ BaghdadFred's post |  #7
Well, it's not like the information was hidden from you. It's out there and readily available.
If you're not going to use the PW Radio Transmitter module (not IR) then you may as well return it and use the Auto-Reset Cordless mode in the Sekonic meter.
Robert
787 views & 0 likes for this thread, 5 members have posted to it.
2903 guests, 162 members online
