Yesterday while shooting an event my 7D didn't seem to make the changes I wanted or at least the ones dealing with the view finder.
I could change my exposure controls, but when I wanted to turn off the grid in the viewfinder. No luck. I was at the correct tab. since it's one of those things I change depending on my mood. I'd make the change go back and look through VF and still there. even tried changing it to number 2 grid. no luck
Same thing for Focus Point. Switched to expanded and only would see the main point in the VF . I could still easily change which one. but in the past I would see the expanded one, but not this time
Is this something that I should just go under the restrore factory settings or how ever that tab is worded. Just take out the batteries for a bit??
With expanded AF, the main point has to lose focus or at least need assist from a surrounding point for it to pop up. Every once in a while, I'll get two points to show up in this mode.
