Thread started 16 May 2011 (Monday) 15:10
Next telephoto lens? What whould I get?
arch.cm
Joined Apr 2011
May 16, 2011 15:10 |  #1
I'm looking to get a Canon telephoto lens... right now I have the Canon EFS 55-250mm IS, but I'm not happy with most of the results... maybe it's me or maybe the lens, but I was looking to invest in a better quality lens. I was looking at the Canon EF 70-200mm f4 L (non IS) or the Canon EF 70-300mm IS. I don't plan on going to full frame for now so either getting an EF or EFS is the same to me... Any advice on which is better? Thanks.
60D|Canon 10-22mm|Canon 85mm 1.8|Canon 50mm 1.8 ii|Canon 70-200mm f4L|Raynox DCR-250|Sunpak PZ42X
Full Gear List
gonzogolf
dumb remark memorialized
Gallery: 559 photos
May 16, 2011 15:12 |  #2
Before you buy a new lens, lets figure out why you arent happy with the one you have. Then we can figure out which upgrade path might be right for you. What are you concerned about with your current lens?
aboss3
May 16, 2011 15:14 |  #3
+1. Tell us what you don't like about 55-250?
Gear | My gear is changing faster than I can update the signature
VoyageEyewear (external link)
arch.cm
Joined Apr 2011
May 16, 2011 15:22 |  #4
Well, the other day I went to the zoo and I just wasn't happy with the sharpness of the photos... Here's an example of a Tiger:
It's just really soft... basically all the pictures came out like that.
Here's some info from the pic:
Shutter speed: 1/128
Aperture: f5
Focal Length: 131mm
ISO 100
Time of the day: 4pm (a bit cloudy)
Full Gear List
TweakMDS
May 16, 2011 15:25 |  #5
Is F/5 wide open @ 131mm? Otherwise I'd try stopping it down a tad more.
1/128th is rather long for this focal length, although IS should be able to handle it.
For this particular example, I'd try to raise the ISO by about 2 stops, and try something similar to f/5.6 - 6.3 at this focal length.
As for your original question, the 70-200 F/4 would be sharper (much sharper), but you'd really be struggling for fast enough shutterspeeds. From what I've seen, the 70-300 isn't a whole lot sharper than the 55-250.
How about stretching the budget for a 100-400 or so?
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr (external link)
"My featured shots" (external link)
arch.cm
Joined Apr 2011
May 16, 2011 15:27 |  #6
Here's a bit of a closeup:
I didn't use any tripod or monopod, it was just handheld... I'm thinking maybe I have to start using one since most come out like this? Or just get another lens..
Full Gear List
gonzogolf
Gallery: 559 photos
May 16, 2011 15:27 |  #7
Looking at that(first) shot, I dont know that a different lens would have made that a better shot. Partially because its a lot of background and so little subject (Zoo photos are tough that way) but at f5 you only have a few feet of sharp focus and most of your shot is soft due to depth of field issues. Judging by the shadow density it wasnt that cloudy and most of your subject is in the shadow side of the image. Take a few shots where the subject fills a bit more of the frame.
tkbslc
May 16, 2011 15:28 |  #8
shutter speed 1/128 on a moving tiger means it is probably a combo of motion blur and AF miss. You should have probably dropped to ISO 400 and did you use AI servo AF?
Taylor
EOS Rp | iPhone 11 Pro Max
robertwsimpson
Joined Jun 2010
May 16, 2011 15:30 |  #9
100% motion blur. Try shooting at ISO400 next time and a much faster shutter. you'll be way happier with the results. I got some superb shots with that lens before I bought my 70-200.
robertwsimpson
Joined Jun 2010
May 16, 2011 15:33 |  #10
here is an example of how sharp that lens can be wide open at 250mm... This is on an XTi at ISO800 also.
IMAGE: http://farm3.static.flickr.com/2620/3784498099_d4bafb7e0f_o.jpg
IMAGE LINK: http://www.flickr.com …/40483547@N07/3​784498099/  (external link)
IMG_3675 (external link) by robertwsimpson (external link), on Flickr
Sirrith
Gallery: 50 photos
Joined Nov 2010
May 16, 2011 15:36 |  #11
Definitely looks like motion blur to me. A better lens won't help you there. My advice is learn to use the gear you have now, then when you know how to use it properly and realise its limitations, upgrade accordingly.
Here are some photos to show you what this lens is capable of:
IMAGE: http://farm6.static.flickr.com/5138/5404521259_2272f9a43c_b.jpg
IMAGE LINK: http://www.flickr.com …s/noobography/5​404521259/  (external link)
IMG_3099 (external link) by noobographer (external link), on Flickr
IMAGE: http://farm6.static.flickr.com/5020/5426607680_e12a770ea6_b.jpg
IMAGE LINK: http://www.flickr.com …s/noobography/5​426607680/  (external link)
IMG_3068 (external link) by noobographer (external link), on Flickr
Don't be deceived by the cheap build and price of the 55-250, it has stunning IQ when used properly. My only gripe with it is the AF which isn't as quick as I'd hope for, and is one of the reasons why I'm considering an upgrade, but I will be keeping the 55-250 for when I need great IQ in a compact package.
-Tom
robertwsimpson
Joined Jun 2010
May 16, 2011 15:36 |  #12
100mm f/5.6 ISO400 on an XTi
IMAGE: http://farm3.static.flickr.com/2671/3842465287_a22d24a580_b.jpg
IMAGE LINK: http://www.flickr.com …/40483547@N07/3​842465287/  (external link)
Looking for something... (external link) by robertwsimpson (external link), on Flickr
arch.cm
Joined Apr 2011
May 16, 2011 15:36 |  #13
Yeah, from reading the comments I probably should give it a few more trys with those settings and see how they come out.
Full Gear List
robertwsimpson
Joined Jun 2010
May 16, 2011 15:37 |  #14
are you using it on the 60d? If so, crank up that ISO!
arch.cm
Joined Apr 2011
May 16, 2011 15:40 |  #15
tkbslc wrote in post #12421218 (external link)
I'm not sure because at first I had it on Al Focus and then switched it to Al Servo... Is Al Focus just as good for these shots?
Also, yes, I was using the lens on a Canon 60d.
Full Gear List
3,372 views & 0 likes for this thread, 10 members have posted to it.
1390 guests, 103 members online
