Hey guys,
I have no experience with DSLR video, but I think it could be cool to get into. I would like to know the best DIY rig or set-up for skating and snowboarding. BTW I have a T2i.
SkateSoft Senior Member 383 posts Joined Jan 2011 More info | May 16, 2011 18:42 | #1 Hey guys, Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
Chippy569 Goldmember 1,851 posts Likes: 1 Joined Dec 2010 Location: Minneapolis, MN More info | May 16, 2011 21:29 | #2 Buy a gopro or contour. Gear List
May 16, 2011 21:38 | #3 Chippy569 wrote in post #12423269 Buy a gopro or contour. Sorry for not clarifying but I wasn't really talking about a new body, more of a grip or something along that nature. Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
kevinballer08 Mostly Lurking 11 posts Joined Dec 2010 More info |
jaycky Goldmember 2,089 posts Likes: 1 Joined Aug 2010 Location: Bancouver okanagan alberta More info | May 17, 2011 02:51 | #5 http://re1000.wordpress.com …dslr-video-handle-review/ 5DM2 /grip Lots Of L's
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | http://www.youtube.com/watch?v=lDhqHAHmFJ0 60D
May 17, 2011 17:18 | #7 cronu wrote in post #12428057 http://www.youtube.com/watch?v=lDhqHAHmFJ0 No need for all the bike grips if you are using the handle. Maybe even just buy road bike handle bar wrap for the top handle. I would suggest using conduit pipe instead of the galvanized steel because it is cheaper and little lighter. Its easy to mount mic and light on there too. They sell that strut at home depot in electrical section. This is the way to go! I will be using this one. Will be going to Home Depot within the week. Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
SteveHodges Mostly Lurking 15 posts Joined Sep 2010 More info | May 17, 2011 22:00 | #8 Got a t2i 8 months ago, loving it http://www.youtube.com/watch?v=84wB0xx_nAg
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | The same guy made a lighter one. Looks nice but aluminum is so expensive. 60D
robtk Member 211 posts Joined Mar 2011 Location: los angeles//boulder More info | May 24, 2011 20:25 | #10 this was $30. i bought one to film my buddies skating. it's pretty stable/simple (just referring to that grip) 5Dmkii ~ Zeiss 21mm f/2.8 ~ Canon 35L
Just got all of the supplies. Do you recommend I use the quick release. Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | If you have quick release already maybe, but it seems just about as much trouble to put the plate on vs. using a screw mount. I just used one from an old side flash holder. 60D
May 25, 2011 17:39 | #13 cronu wrote in post #12473180 If you have quick release already maybe, but it seems just about as much trouble to put the plate on vs. using a screw mount. I just used one from an old side flash holder. I bought a 1/4- 20 screw that fit the dimensions of a tripod screw but I think it may be to long and if it is too long it could cause shutter issues. Now I'm thinking I might use the top of a old crappy tripod. Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | May 25, 2011 20:32 | #14 I added a few pics without the camera on the cage and of the bottom to give ya a clearer view. An old tripod should do the trick nicely. I just like being able to balance the whole setup with different lenses. Hope this helps 60D
May 25, 2011 21:36 | #15 cronu wrote in post #12479714 I added a few pics without the camera on the cage and of the bottom to give ya a clearer view. An old tripod should do the trick nicely. I just like being able to balance the whole setup with different lenses. Hope this helps http://www.flickr.com …s/72157626672694031/show/ I like what you did with it. What did you use on the bottom instead of the aluminium. Gear- 550d, KONICA Auto S2, Pentak ZX-50, 18-55, 55-250, YN-560
| Latest registered member is Thunderstream 1872 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
