Hello folks.
As the title suggests, I recently purchased an XSi with the 18-55 IS kit lens at a local warehouse store. (I was very shocked to see that they still had it in-stock.)
I paid $449.99 with tax for it.
However, there are a couple of problems.
1. The camera was technically a display model, and as such, it had a few clicks already on the shutter. (30 to be exact.) For most of its life, it was kept powered off under a glass display case, but someone must have taken a few test shots with it prior to placing it there. At least, that is my assumption anyway.
2. Upon using the camera, I unfortunately came across the dreaded Err 99 message. This appeared while I was using Live View and it actually went away by itself after I let it sit for about a minute or so. (No, I did NOT have to power off the camera or take the battery out just to get the message to go away. Strangely enough, it left on its own accord, and I have not gotten the message to appear again.)
3. The internal mirror seems to have a faint mark on its surface. It has absolutely no impact on my photos whatsoever, but it is a bit disheartening to see all the same.
So what do you think guys? Should I just return this thing and be done with it, or should I keep it and roll the dice?
