Are flashes and light-bulb supposed to use together? What i realized is my flash is much stronger than my light-bulb, so I don't know how much can bulb add to the exposure of my image.
cfvisuals Senior Member 866 posts Joined Mar 2011 Location: San Diego More info | May 17, 2011 21:35 | #1 Are flashes and light-bulb supposed to use together? What i realized is my flash is much stronger than my light-bulb, so I don't know how much can bulb add to the exposure of my image.
CiM_Photography Goldmember 1,813 posts Joined Sep 2009 Location: North Andover, MA More info | May 17, 2011 21:58 | #2 By lightbulb are you referring to ambient lighting, like a lamp? Or are you talking about modeling lights? Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer
airshaq20 Senior Member 667 posts Joined Jul 2006 Location: East Coast, USA More info | May 17, 2011 22:10 | #3 calvinjhfeng wrote in post #12430274 Are flashes and light-bulb supposed to use together? What i realized is my flash is much stronger than my light-bulb, so I don't know how much can bulb add to the exposure of my image. Flash is controlled by your aperture, light bulb adds to your ambient light so it is controlled by your shutter speed. So to answer your question, the light bulb will not affect the subject that is lit by your flash but it will make your ambient brighter depending on how fast your shutter speed is.
May 18, 2011 00:38 | #4 CiM_Photography wrote in post #12430411 By lightbulb are you referring to ambient lighting, like a lamp? Or are you talking about modeling lights? Flash and regular house lamps don't balance well together, from a color temp standpoint. Flashes have the wonderful ability to be gelled to match nearly any light source, so you could always color correct the flash head to match the ambient... Alternatively, set your camera to shoot outside of the ambient exposure levels so that your flash has to push to shoot over it. That way, the ambient light won't play a large role in determining the coloration of the photo. Hope that makes sense. i use 5500K 45watt lightbulbs. So technically it isn't house lamps, it is daylight temperture.
May 18, 2011 00:39 | #5 airshaq20 wrote in post #12430496 Flash is controlled by your aperture, light bulb adds to your ambient light so it is controlled by your shutter speed. So to answer your question, the light bulb will not affect the subject that is lit by your flash but it will make your ambient brighter depending on how fast your shutter speed is. I usually put my flash on manual, it isn't controlled by anything, so I am puzzled.
CiM_Photography Goldmember 1,813 posts Joined Sep 2009 Location: North Andover, MA More info | May 18, 2011 07:38 | #6 I think the best method is to read up on www.strobist.com Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 18, 2011 10:00 | #7 'flashes and light bulbs' ...that describes a studio strobe! Flash is daylight balanced, modelling light is incandescent (about 3200K) and the two are very commonly used together. Of course, the intensity difference is typically more than 4EV difference...f/5.6 (modelling light) vs. f/22 (flash), and for all intents and purposes the incandescent source does not contribute much to the overall exposure -- about 0.2EV if only 3EV difference in intensity (and it is a stuggle to make the difference that little!). You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
troymm Senior Member 268 posts Joined Jul 2007 Location: Orange County, CA More info | May 18, 2011 10:05 | #8 Are you talking about strobes and constant lighting together? 1D MKIII, 5D MKII, 40D, 24-70L, 35L, 70-200 f/2.8L IS, 135L, 85 1.8
| Latest registered member was a spammer, and banned as such! 2804 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
