Thread started 18 May 2011 (Wednesday) 10:33
DIY snoot?
coeng
Joined Nov 2002
May 18, 2011 10:33 |  #1
Does anyone have ideas for a DIY snoot?
I use Genesis 200s.
5D2, 600 EX-RT, STE-3, 24-70L, 70-200L f/2.8 IS II, 50 f/1.4, 85 f/1.8
TMR ­ Design
Joined Feb 2006
May 18, 2011 10:48 |  #2
With items like this available, are you sure you want to bother with a DIY snoot. This has the Elinchrom mount and the price is right.
http://cgi.ebay.com …m256385442a#ht_​500wt_1156 (external link)
Robert
coeng
Joined Nov 2002
May 18, 2011 10:50 |  #3
TMR Design wrote in post #12433512 (external link)
Need it for tomorrow and don't have one.
gfontenova
Joined Apr 2011
May 18, 2011 10:56 as a reply to  @ coeng's post |  #4
Get thee to a craft store!
Velcro, black craft foam, and gaffer's tape (or black duct tape).
Get the velcro with the hooks one one side and the loops on the other.
Tape enough craft foam together to circle the ring on the strobe. Use the velcro to cinch it onto the ring, and then cinch the end of the snoot down to the required diameter the same way.
I've done this with a 160WS strobe, and nothing caught fire. YMMV.
I'm Geoff.
I've got some cameras, some lenses, and some lights. You can see how I use them at:
My Website (external link) | Flickr (external link) | Facebook (external link) | My Blog (external link)
C&C on any of my shots is always welcomed!
TMR ­ Design
Joined Feb 2006
May 18, 2011 10:59 as a reply to  @ gfontenova's post |  #5
Ahh the immediacy. Gotcha!
You don't have to worry about fire as long as you:
1. Make sure that none of the materials used for the snoot are close to or touching the flash tube.
2. Do not use the modeling lights.
Robert
Kechar
Joined Mar 2011
May 18, 2011 11:03 |  #6
Pringles potato chip can, manual can opener to remove bottom, flat black spray paint to dull silver inner lining, duct tape to attach!!!
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
jim_escalante
May 18, 2011 12:19 |  #7
If you do not have it, well then it will not help. I keep a roll of black cinefoil for just such times, when I need to shape a light. Of course, the first time I needed it, I did not have it. Ha, I bought a roll the very next day.
jim
coeng
Joined Nov 2002
May 18, 2011 13:53 |  #8
gfontenova wrote in post #12433555 (external link)
Got a pic of this so I can get an idea for what you mean?
kokakaste2
May 18, 2011 15:33 |  #9
Kechar wrote in post #12433592 (external link)
Don't think the can will be wide enough for studio strobe. But this is great way to get snoot for speedlites. :)
Oskar (Oscar) - stuff I use- Flickr (external link) - My Facebook page (external link) :)
gfontenova
Joined Apr 2011
May 18, 2011 15:34 |  #10
coeng wrote in post #12434579 (external link)
Unfortunately, I don't have any shots of this getup, but, I might be able to cobble it back together when I get home in a few hours. If you're pressed for time, check out the below:
http://www.f1point0.co​m …ond-diy-adjustable-snoot/ (external link)
I did the same thing, except I had to overlap two pieces of foam on the long edge (using the tape) to get it to wrap around the light.
I also didn't bother with the white foam, I just used the black, which probably cost me some light.
The rest of the mechanics of how it hangs together are all there, though.
Hope that helps!
I'm Geoff.
BrickR
Joined Mar 2011
May 18, 2011 16:12 |  #11
Got a cereal box or cardboard? In a pinch, a snoot is probably the easiest modifier to DIY. Post a pic of whatever you go with thou!!
My junk
The grass isn't greener on the other side, it's green where you water it.
Csae
May 18, 2011 16:33 |  #12
Home hardware store, a set of Vent Duct reducers.
Heres a pic to get an idea.
IMAGE: https://www.horticulturesource.com/images/cache/large_thumbnail/736211.jpg
Measure the diameter of a eli speedring, then start with that and work your way down. You can use flat sheet cuters to get a rough speedring mount cutout, or get the first vent reducer larger then your speedring, and cut out 4 tabs on the reducer, bend them, and drill em, then attach to a speedring of your choice. If you don't wanna drill through any of your speedrings, get the first vent reducer smaller then the speedring, cut out of 4 tabs, bend them, and clip them to the speedring, but eli speedrings have little clearance i found, so its hard to do.
Some flat black paint outside and inside should do a dirty job, the metal is durable enough, though i don't recommend using the modelling light much.
The more reducers you use, the more control, i suggest attaching them with tape or just velcro tabs instead of gluing them so you can remove/adjust the spot a little.
-Hope it was in time.
Feel free to call me Case.
CasePhoto.ca (external link) - FanPage (external link)
-Montreal based Photography.
4,894 views & 0 likes for this thread, 8 members have posted to it.
DIY snoot?
2804 guests, 169 members online
