I would like to know how to remove the centre column on my Gitzo 2531. For macro and close ups of wild flowers I can't go low enough with the centre column attached. Thanks.
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | May 18, 2011 20:09 | #1 I would like to know how to remove the centre column on my Gitzo 2531. For macro and close ups of wild flowers I can't go low enough with the centre column attached. Thanks. www.eaglesnestphotography.com
daveyboi Senior Member 652 posts Likes: 1 Joined Aug 2009 Location: Stockton, CA More info | May 18, 2011 20:26 | #2 remove hook on the bottom? 5D Mark II // 17-40L SOLD
May 18, 2011 20:34 | #3 daveyboi wrote in post #12436832 remove hook on the bottom? No, the whole column, so I can have just the base plate only attached. www.eaglesnestphotography.com
RovinHoot Junior Member 29 posts Joined May 2008 Location: Japan More info | You'll have to buy a tripod base, for example:
May 18, 2011 20:42 | #5 RovinHoot wrote in post #12436904 You'll have to buy a tripod base, for example: http://www.markinsamerica.com/MA5/TB-21.php No my friend, I had it removed last year and I re attached the centre column for in Winter I don't do close ups/macro.I just forget how I did it. www.eaglesnestphotography.com
daveyboi Senior Member 652 posts Likes: 1 Joined Aug 2009 Location: Stockton, CA More info | May 18, 2011 20:50 | #6 like here? 5D Mark II // 17-40L SOLD
huntersdad Goldmember 4,870 posts Likes: 652 Joined Nov 2008 More info | Unscrew the hook on the bottom, remove entire column from tripod, unscrew center column from head mount, place head seat on tripod and screw the hook straight to the head mount. That's how I did it anyway. Just make sure you tighten the hook to seat connection everytime before you use it so your camera and lens don't go crashing. Facebook
| Latest registered member is ANebinger 1066 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
