Thread started 19 May 2011 (Thursday) 05:31
T3i: can I fire wireless flash only without built in flash?
stukovx
Joined Apr 2011
May 19, 2011 05:31 |  #1
Just got my T3i today and wanted to use my 580ex flash wirelessly. Problem is, the only way I can seem to get it to fire is if I flip the built in flash up as well. I've been fiddling around with the settings and there is an option with a little icon which says I should be firing my 580ex only but that doesnt seem to be the case. Worse comes to worse I'll just ghetto mod it and stick something in front of the built in flash to block the light.
aaronhentges
May 19, 2011 05:36 |  #2
thats how it talks to the other flash is through its own output, if setup the light emmited from the on cam flash is not ehough to undermine the off cam flash. so if you block it it will block the wireless feature of the flash
Deltona, Florida
Kechar
Joined Mar 2011
May 19, 2011 07:34 |  #3
You'll need a wireless transmitter and receiver to just fire the off camera flash.
Or you may be able to get a remote thing to go in your hot shoe wired to your flash.
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
eduardofrances
May 19, 2011 07:53 |  #4
stukovx wrote in post #12438839 (external link)
Does the pop up flash contributes to the exposure? normally it shouldn´t be the case, I´m not that familiar with Canon´s system (used it only a couple of times but with a 1D MKIII and a ST-E2) but check out your user manual to see if there´s such an option.
Some people use a piece of exposed film.
http://flickr.com/phot​os/eduardofrances/ (external link) :D
msowsun
"approx 8mm"
Gallery: 18 photos
May 19, 2011 08:01 |  #5
If you choose the right option, the T3i flash has almost no output when it triggers the slave flash. What "problem" are you experiencing?
If you shoot into a mirror, or wide open at close range and high ISO, you will see some of the light from the trigger flash.
Indoors you can deflect this light and it will bounce off the surrounding areas and still reach the slave.
Agent ­ 655
May 19, 2011 12:10 |  #6
One of the wireless settings on the 60D (probably the same on the T3i) has an image of the pop up flash: remote flash. You can select that to have just the popup flash, both flash, or wireless only flash.
Even on the wireless only mode the popup looks like it flashes, but that is the trigger flash before the actual exposure.
You can also blance the flash power between the popup and wireless. I like to use the wireless flash off to the side a bit, then dial down the exposure compensation for the pop up to add some fill light.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
May 19, 2011 12:21 |  #7
That communication flash is not bright enough contribute to the light in the image at all; it is ONLY enough to get the information from your camera to the flash to trigger it appropriately.
If you need longer range, or to trigger remotely in high ambient light conditions, you'll want to get a radio trigger of some sort.
HughR
May 19, 2011 14:47 |  #8
On my 60D, and I presume also the T3i, the pop-up will trigger my 430EX wirelessly from at least 25 feet away even outdoors with sun on snow. I did the test back in February, and the remote flash fired every time from that distance as long as there was line of sight. Line of sight is not necessary inside in moderate sized rooms, as reflections off walls and ceilings will trigger the external flash effectively.
As others have said above, the pop-up produces far too little light to affect exposures if you set the camera to wireless only. The pop-up can produce modest amounts of fill light if you set the camera to (wireless + pop-up).
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
stukovx
Joined Apr 2011
May 19, 2011 16:56 |  #9
ahhhh, thanks for all the input everyone, I didn't know the built in flash used a flash to transmit the signal. I thought it would do so without flashing. I'll give it a try and see how it turns out.
Thanks!
10,517 views & 0 likes for this thread, 8 members have posted to it.
1200 guests, 167 members online
