Thread started 19 May 2011 (Thursday) 14:25
bad quality photos on Facebook
binderring
Joined Apr 2011
May 19, 2011 14:25 |  #1
Anyone know how to fix this problem? Most of my pictures look great in Lightroom but whenever I upload it on fb, it seems to have a lot of noises.
cdifoto
Don't get pissy with me
May 19, 2011 14:30 |  #2
It's not noise; it's digital compression. It happens automatically. The only solution is to not upload your photos to facebook if it concerns you that much.
mckinleypics
May 19, 2011 14:31 |  #3
You can share a link to flickr instead.
Dave
7D, 70-200mm 2.8 L IS, 24-70mm 2.8 L, 50mm 1.4, Tokina 11-16mm 2.8, 580EXII
My Flickr (external link)
ToddR
May 19, 2011 14:34 |  #4
Is it still useful to size to 720 pixels on the longest side of an image before uploading to Facebook?
Is there a file size limit that, if not exceeded, will not be recompressed on Facebook's end?
Chelsey ­ Somohano
May 19, 2011 14:37 |  #5
We usually upload ours at 72dpi and 700 on the longest size. Seems to make a little bit of a difference. Remeber, downloaded high quality images gives users the ability to download those high res files.
50D | 35L | 24-70L | 50 1.8 |
website: http://www.hurst-photography.com (external link)
"Buying a camera doesn't make you a photographer - It makes you a camera owner."
Staszek
May 19, 2011 14:55 |  #6
Chelsey Somohano wrote in post #12441330 (external link)
Users can dl photos regardless of quality. Also dpi does not make a difference in digital format.
SOSKIphoto (external link) | Blog (external link) | Facebook (external link)| Instagram (external link)
Shooting with big noisy cameras and a bag of primes.
binderring
Joined Apr 2011
May 19, 2011 15:05 |  #7
Thanks guys!
tonylong
...winded
Gallery: 60 photos
May 19, 2011 22:51 |  #8
In Lightroom just make sure that you Export to an FB-size image (720 pixels max length). As was said, the ppi figure doesn't matter -- you set Export to dimensions in pixels and just enter 720 or smaller in the widest dimension. Your jpeg quality shouldn't be a big concern, you can play with it, say 50-60-70 but really for Web size images it matters little (unless you have people who are downloading them and trying to print them. Anyone who gets it in their head to try that from Facebook is in for well-deserved disappointment.
Also, made sure that Export is converting them to the sRGB color space so they don't look odd color-wise.
The last consideration that you can play with is Output Shapening -- play with the different levels in the Export dialog and see how they suit you!
Tony
Mark1
May 19, 2011 22:57 |  #9
Staszek wrote in post #12441457 (external link)
Not for image quality on screen, but it will for file size.
canonman78213
May 19, 2011 23:43 |  #10
Just saw this post and although the shots I post up to FB load up fine, the watermark and the watermark ONLY are blurry on most shots. The actual image is great. Thinking maybe a FB compression issue? just odd that it doe NOT effect the actual images, only the watermark; which I put on in Lightroom 3. Just curious if anybody has come across this too when posting watermarked shots to FB using the Lightroom 3 watermarking. And if so, if there's a way to modify the watermark so that it is not blurry on FB. On all other sites it's just fine.
[B]Canon 5D mrk II,Canon XSI, gripped. 5D classic,70-200 2.8L IS, Canon EF-S 10-22mm/3.5-4.5USM, 50mm/1.8 nifty fifty mrk I (NOT the newer plastic fantastic) 35mm/1.4LmrkI, 85mm/1.2L, 200mm/2.8L mrk I, 1.4 mrk IIand 2X mrkI canon TCs, Canon 430EX II, Induro Alloy 6M Tripod A-014 with Manfrotto 484RC2 Mini Ball Head with RC2 Rapid Connect Plate
Chelsey ­ Somohano
May 20, 2011 00:10 |  #11
Right, but wouldn't you rather them download a 700px wide image rather than a 1024px image. I know if my clients want a high-res image, they pay for it.
tonylong
...winded
Gallery: 60 photos
May 20, 2011 00:31 |  #12
Mark1 wrote in post #12443998 (external link)
For the Web, ppi/dpi is meaningless. The Web only "knows" the dimension in pixels. And, unless you are dealing with a commercial lab/print shop, it is also meaningless -- you specify a print size and they handle the sizing unless you want to get into resampling an image. But, for the Web, there is only one ppi, and that is that of the monitor which a viewer is using, which is out of your control! And, that hasn't been anywhere near 72 ppi for decades -- these days it is closer to 100 ppi:)!
Tony
Staszek
May 20, 2011 00:40 |  #13
Chelsey Somohano wrote in post #12444383 (external link)
Correct. Which is why all my facebook pictures are uploaded at 640p :D
René ­ Damkot
May 20, 2011 01:19 |  #14
No, it won't.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Mark1
May 20, 2011 08:03 |  #15
René Damkot wrote in post #12444707 (external link)
No, it won't.
If you know what you are doing it does.
http://photofocus.com …to-myths-ppi-does-matter/ (external link)
16,244 views & 0 likes for this thread, 18 members have posted to it.
Latest registered member is Sandro Bisotti
1678 guests, 161 members online
