Thread started 19 May 2011 (Thursday) 16:15
Eneloop Charge Time?
PeaceFire
May 19, 2011 16:15 |  #1
Do they usually take 5 hours to charge? I started charging a set at 10AM and it's 2:15 and they still aren't charged! Still flashing green.
My Gear List / My Blog (external link)
yourdoinitwrong
May 19, 2011 16:21 |  #2
I haven't timed mine from being dead but that doesn't sound too far out of line. They take quite a while to charge. Usually I put mine on the charger at night and let them go until morning.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
PeaceFire
May 19, 2011 16:32 |  #3
Thanks. The box says 220 minutes for 4 AAs (a little over 3 hours) so I was worried something was going wrong with my charger. Glad to hear this is normal-ish.
BrickR
Joined Mar 2011
May 19, 2011 17:51 |  #4
My Eneloops always seem to take forever to charge. I just assumed it was because I wasn't using an Eneloop charger and was using my Energizer charger. Guess they're just slow to glow.
My junk
The grass isn't greener on the other side, it's green where you water it.
sydney7D
May 19, 2011 18:09 |  #5
Charge time will depend on what sort of charge/amperage you are putting into the batterie/s.
Hobby chargers are great for this kind of stuff as they can charge your batterie/s really quick and to a good capacity.
If you do a search for a 'imax b6 charger' you'll find they go for around $30 and will charge just about anything.
EOS 7D and some other stuff. :)
Wilt
May 19, 2011 18:53 |  #6
Charge time is dependent upon battery capacity and charge rate.
Time = (Capacity / charge rate)
Generally the most healthy rate for NiMH is 200 mA/hr to 500 mA/hr. And the capacity for most NiMH AA batteries is in the range of 2500-2700 mAh.
You can charge them faster (more mA/hr) but the heat generated at the faster rate is not good for batteries...best to have fan cooling of the batteries if charged at a faster rate!
PixelMagic
May 19, 2011 19:26 |  #7
Wow...good to know that. My MAHA/Powerex C-9000 charger defaults to 1000 mA/hr.
Wilt wrote in post #12442683 (external link)
tim
Light Bringer
May 19, 2011 22:11 |  #8
Unfortunately Wilt's information is incorrect. Have a read of the article on battery university, (external link) a great resource on batteries.
NiMH cells should be charged at about 0.5C, so a 2000mah cell should be charged at 1000mah. This is the same recommendation that Maha/PowerEx makes. At this speed I find cells don't get particularly hot, but at 1C they can do.
The only exception is if the cells get hot, and a good charger monitor this for you. The C9000 (external link) is what I use, along with a C801D.
PixelMagic
May 20, 2011 05:50 |  #9
Thanks for that link, Tim.
tim wrote in post #12443723 (external link)
Wilt
May 20, 2011 09:33 |  #10
Wait Tim, there is no 'incorrect' to the fact that 200-500 mA/hour is less than the 1000 mA/hour upper rate of charge, is there?! :)
Now having smarta55ed back, I do note the comment in that linked article, "It is difficult, if not impossible, to slow-charge a NiMH battery. At a C‑rate of 0.1 to 0.3C, the voltage and temperature profiles fail to exhibit defined characteristics to measure the full-charge state accurately and the charger must depend on a timer." And in view of that remark, and in spite of the fact that my charger is not timer based, I would start to use my charger's faster rate now.
GregoryF
May 20, 2011 10:18 |  #11
:grin:Anyway back to the OP's question. I find (using the sanyo charger) that anywhere from 5 to 8 hours for the batteries to fully charged. Nothing wrong with your's!:)
6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!:cool:
A simple hobby gone horribily wrong
Todd ­ Lambert
I don't like titles
May 20, 2011 10:23 |  #12
Yep, I tend to allow em to charge overnight - in the supplied charger. I have multiple sets, so multiple chargers... not too bad. Just have to make sure I put them in the wall the night before.
1,859 views & 0 likes for this thread, 9 members have posted to it.
2844 guests, 161 members online
